Oil Primer Over Water Based - Painting - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 10:05 PM   #1
Rewards Points: 260
oil primer over water based
Can I use an oil primer over a water based primer? I painted some bare cedar with zinnser 123 and forgot to spot treat the knots. I can also see some tannin showing through. I'm thinking about either spot priming the knots or just putting a coat of cover stain on top.
bluefitness is offline   Reply With Quote
Old 06-05-2009, 05:16 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
No problem, I would go over everything with oil just to make sure.
Old 06-06-2009, 06:35 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
^^^Ayup^^^
slickshift is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
Spot repair of water based poly hardwood floor flyfisherman Flooring 5 05-06-2009 09:00 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
