Old 09-17-2012, 11:28 AM   #1
Oil polyurethane over latex paint
I've seen conflicting answers to this but I want to clarify if anyone can help.
I have some laundry room lockers that are made of pine and painted with black latex paint. I'd like to cover with an oil polyurethane I have. The room gets absolutely no exposure to sun (I have read that the finish can yellow over time).
Given that the paint is black, it's a laundry room (i.e. don't care if things are not perfect), and gets no sun exposure, any "harm" in using the oil based poly? By harm I mean I want to make sure it's not going to take the black paint off or start flaking off over time or something like that.
Is it a big deal? I'm trying to use it since I have it to avoid buying another product. Also, I believe it will require less coats if I use the oil.
fishacura is offline   Reply With Quote
Old 09-17-2012, 11:35 AM   #2
If it's painted then why do you need to add a sealer?
Old 09-17-2012, 11:37 AM   #3
The finish is very flat and I'd like to better protect it and add some shine/smoothness.
Old 09-17-2012, 11:45 AM   #4
Then just lightly sand and go over it with enamel gloss or semi gloss paint.
If you use poly it will yellow and also wear off where the handles are.
Old 09-17-2012, 11:57 AM   #5
Great feedback and thank you for your assistance. Is there such a thing as "clear semi gloss paint"? I didn't want to change the color....or for that matter a latex based poly???
Old 09-17-2012, 12:43 PM   #6
There is absolutely nothing wrong with applying one or several coats of an oil poly over a flat latex paint. There will be no issues of incompatibility - they will work fine with each other. You are right that the oil poly will yellow some, over time, but over black it really won't matter or be that noticeable. If you are concerned about yellowing, there are latex (acrylic) polys in a semi-gloss finish that are pretty durable - and would work fine.
As long as the black paint is clean, and in good sound condition, applying a coat of oil poly is a great way to provide further protection to your lockers. The poly will NOT wear off any faster around the handles than would an "enamel" or "semi-gloss" paint - matter-o-fact, the oil poly will provide greater protection than either around the handles, knobs, whatever.
The biggest concern I'd have with the oil poly is applying it in a basement, in a laundry room - but that'd only be if your basement is not dry, or if you already have a mildew problem due to high humidity - if so, mildew can grow on an oil (alkyd) finish easier than on a latex (acrylic) finish. If that's not an issue, stay with what you've got, it'll be a well protected project.
ric knows paint is offline   Reply With Quote
Old 09-17-2012, 12:50 PM   #7
My point exactly (per my original post). Completely different response lol! These were my thoughts but Joe seems to really disagree (and has thousands more posts...)
In honor of election season, let the debates begin
BTW, the product is MINWAX quick drying poly....satin finish
Old 09-17-2012, 01:33 PM   #8
Rubbin walls since'79
Brushjockey's Avatar
If you need to listen to Joe or Ric- take ric every time...
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-17-2012, 01:36 PM   #9
Well I certainly didn't mean to start a fight!!!
Old 09-17-2012, 01:47 PM   #10
No fight. Fact.
Old 09-17-2012, 01:56 PM   #11
Well Ric seems more in line with what I have read (meaning it's probably not the BEST alternative, but there's really not much harm in doing it as long as you know about the yellowing, particularly if it's a light shade of paint AND is sun exposed). But I really can't find anything to warrant not doing it in my circumstances so I'll go for it. THANKS....saved me some $$ and some time...
Old 09-17-2012, 02:04 PM   #12
Doer of Many Things
poppameth's Avatar
Why not just put water based urethane over it instead of oil urethane? Minwax Polycrylic is in just about every store you could imagine. It won't yellow either.
poppameth is offline   Reply With Quote
Old 09-17-2012, 04:52 PM   #13
1. Was at Depot and they only had it in gallons (another brand too...not the brand I want)
2. Already have oil based...why spend the $$$
3. Less coats required than latex based
That's it in a nutshell
Benjamin Moore exterior flat latex paint warranty Andee77 Painting 2 06-27-2012 08:32 AM
exterior oil-based polyurethane over exterior latex paint? exitstrategy Painting 5 05-29-2012 05:37 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
oil polyurethane over latex paint Nancy Dreger Painting 8 08-31-2011 05:37 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
