Oil Over Oil On Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 11-23-2013, 04:55 AM   #1
Oil over oil on cabinets
Good morning, all. Newbie here. I'm going to be repainting cabinets that were painted 10 or more years ago with white-now-nicely-yellowed oil paint. I'm going to be using oil based again, and I know about the typical sanding/tack cloth prep and all that, but my issue is this: I am at a multi-family rental property, and time is everything. Yes, I want to do the work right, but at the same time it just needs to get done in as short a time as possible. The current surface, though yellowed, is pretty glossy and smooth. I will appreciate all pointers anyone can offer. I look forward to being a member of this site!
rondon is offline   Reply With Quote
Old 11-23-2013, 08:25 AM   #2
K&B Designer
Live_Oak's Avatar
First, don't go with oil. Choose an acrylic enamel after priming with a oil based bonding primer. It won't yellow next time. Second, if the current paint is truly adhered well, then a liquid deglosser could possibly be your first step rather than sanding. If there is any loose paint though, sanding is the only way to go.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 11-23-2013, 09:26 AM   #3
Rewards Points: 13,444
Your skipping an important step. They need to be degreased before doing anything.
Old 11-23-2013, 11:18 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
He likes the yellowed look. A lot of people do. I would stick with the oil. Make sure there is no grease like joe said, scuff sand and then paint away.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 11-24-2013, 06:16 AM   #5
Thanks, all. I don't really "like" the yellowed look. I was being cynical. I'm just looking for pointers on the best way to do it quickly, considering the type of property. I'm thinking my best bet is the liquid deglosser. The place is occupied, and I want as little mess and interruption as possible.
Old 11-24-2013, 09:09 AM   #6
Painting Contractor
Rewards Points: 87
I would not rely on the liquid deglosser alone. It works good for acrylic paints, but will not adequately etch the oil based surface. The consequences of not sanding first will be irreparable later.
kkeith is offline   Reply With Quote
The Following 2 Users Say Thank You to kkeith For This Useful Post:
chrisn (11-24-2013), ToolSeeker (11-24-2013)
Tags
cabinets , oil-based paint
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 63 01-10-2017 05:50 AM
Adding 12" upper cabinets to already 42" ? DIY-Her Kitchen & Bath Remodeling 10 02-23-2016 12:04 PM
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Refinishing old Cabinets ryanb4614 Carpentry 4 08-18-2011 06:24 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
