Oil To Latex Error - Painting - DIY Chatroom Home Improvement Forum
Old 02-09-2007, 10:50 PM   #1
oil to latex error
I painted our front door with high gloss latex enamel and I think that I should have primed it forst. It is a very old house and likely it was oil base paint that I painted over. It lookes awful and is peeling in a few small spots. What can I do to fix it now that it is done?
my5cats is offline   Reply With Quote
Old 02-10-2007, 07:41 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Sand it all off.
Go to the paint store and speak to someone to find the right kind of primer and how to properly prep. the door surface before adding the primer.....
(It's not the end of the world, mistakes happen, but can easily be fixed - you could use a palm sander to make your work a little easier)
- Build Well -
Old 02-10-2007, 08:24 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Yes, you'll need to scrape off what you can, then sand the rest smooth
Ask at your local paint shop (not a big box) what they carry to do your project properly
I suspect it will be an oil-based enamel underbody (primer), then your latex enamel paint
Depending on the shop and what the door is made out of, it may be a slightly different combo
slickshift is offline   Reply With Quote
Old 02-10-2007, 08:25 AM   #4
That's what I was afraid of! Thanks for clarifying...
Embarrassingly stupid question about latex paint joeyboy Painting 7 08-20-2007 09:25 PM
Do latex and water mix? eric s Painting 2 11-28-2006 03:25 AM
trane furnace with inducer blower error tjh57 HVAC 1 10-22-2006 07:45 PM
PAYNE Pressure switch error code 23 WRKPA HVAC 1 02-04-2006 06:37 AM
Latex over Gloss 'Andyman Painting 4 10-02-2005 08:49 AM
