Oil-based Or Water-based Lacquer Finish For Interior Doors? - Painting - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 02:50 PM   #1
Oil-based or water-based lacquer finish for interior doors?
At the current stage of our remodeling I have dark-color stained doors and planning to do poly/varnish finish. Which one would look better and be more durable: water-based poly/varnish or oil-based? Regarding the look, I mean which will fit in our modern style interior. I've never done a finish and I don't want to screw anything in the way the doors will look. That's why sorry for perhaps stupid question...
mzaslavsky is offline   Reply With Quote
Old 07-26-2013, 02:58 PM   #2
Dave Sal's Avatar
Rewards Points: 720
I think an oil based finish will be more durable in the long run but that shouldn't be an issue in an interior location. I replaced most of my builders grade hollow core doors with solid core six panel oak doors a few years ago. I stained them a dark color to match the rest of the trim (Minwax Jacobene stain) and tried to match the finish so it had the same sheen. I used satin finish poly and it was a perfect match. You should try to match the finish of your other woodwork in the home, flat, satin, or glossy.
Dave Sal is offline   Reply With Quote
Old 07-27-2013, 08:44 PM   #3
Rewards Points: 258
How do you plan to apply the varnish? If spray, then I would highly recommend acrylic poly. If you plan to use the brush then definitely go with the oil base. If you choose to go with oil do a little research, some polyurethanes only have 5% urethane while others have 51%. Write the manufacture and question them as to the % content.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 07-27-2013, 08:49 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Look at Zar finishes. They are excellent across the board.
Fave waterborne ( hybrid alkyd in waterborne ) is Zar's Ultra Max satin.
Easy to brush like an oil- very little odor, dries fast, but not too muc
h like most waterbased.
Great stuff.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-27-2013, 09:00 PM   #5
Too Short? Cut it Again!
One nice thing about waterbased clear coats is they will not yellow like oil-based ones will. Oil finishes can be a little easier to work with as they do not dry so fast as polycrylic type materials. With either you want to work with quality brushes suited to what you choose. And do not overwork the finish or you will leave brush marks.
Old 07-28-2013, 08:25 AM   #6
cdaniels's Avatar
I'm with Brush..Zar is the best WB I have used and I have used a lot of them.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 07-28-2013, 09:10 AM   #7
Jmayspaint's Avatar
Rewards Points: 534
Stays Clear was my favorite... Until I used the Zar. Most of the Zar products I've used have impressed me.
Jmayspaint is online now   Reply With Quote
Old 07-28-2013, 07:11 PM   #8
Rewards Points: 5,978
Another vote for Zar.
Old 07-30-2013, 08:48 PM   #9
Painting Contractor CT
Rewards Points: 77
Post
I would go with oil-based for your interior doors. Good Luck!
KD PAINTING is offline   Reply With Quote
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 08:57 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
