Oil Based Painting - Painting - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 07:18 PM   #1
Oil Based Painting
Hi All,
I know that when using latex paints, the brushes and rollers need to be conditioned by soaking them in water to make them damp before painting.
Is the same sort of thing done when using oil based paints? Should I condition the brushes and rollers in a similar manner with mineral spirits? If so, which particular one?
Thanks in advance,
Bob
Bob Guercio is offline   Reply With Quote
Old 03-10-2011, 08:05 PM   #2
Gymschu's Avatar
Rewards Points: 232
Pre-condition with whatever type thinner your oil base requires for clean-up. Most alkyds clean up with mineral spirits so pre-condition with MS. Shellac based coatings require lacquer thinner, other oil-bases require other types of thinners. Anyway, it is a good idea to pre-conditon, but, it's not the end of the world if you don't.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
Bob Guercio (03-10-2011)
Old 03-10-2011, 09:29 PM   #3
Rewards Points: 256
Hey Bob,
If you're using a new bristle brush, after you remove it from the wrapper, slap the bristles a few times on the edge of a counter to remove any loose bristles. Nothing worse than have a bristle come out on newly painted surface. Wrap your roller cover (if you're using one) with masking tape a couple of times to remove any fuzz or lint.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 03-10-2011, 10:26 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
All that the pre-conditioning of your brushes does is make the paint run out of your brush and down your arm.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
chrisn (03-11-2011)
Old 03-11-2011, 06:05 AM   #5
Mathew,
I disagree!
The preconditioning makes the brushes extremely easy to clean. With a light film of water on the bristles, the paint is not able to dry to them and easily comes off under running water.
Also, I haven't had any problem with preconditioning making the paint run out of the brush down my arm.
Bob
The Following User Says Thank You to Bob Guercio For This Useful Post:
boman47k (03-11-2011)
Old 03-11-2011, 03:02 PM   #6
Super Master Painter
Ole34's Avatar
Originally Posted by Bob Guercio View Post
Mathew,
I disagree!
Bob
you think that ''water'' sticks around all day while your painting?? ............lol, eventually that ''light film of water'' mixes with the paint and becomes a non issue..........
its all in your head trust me
Ole34 is offline   Reply With Quote
Old 03-11-2011, 03:07 PM   #7
Ole34's Avatar
i pre-condition my brush with WD-40 ............but we already went down this road before........it works, try it
Old 03-11-2011, 04:26 PM   #8
True.
However, today after spending 13 hours painting, I cleaned my 2.5 inch brush no fewer than about eight times. Some cleanings were necessitated by changing colors while others were for the reason of having a clean and neat brush.
I would say that the time spent cleaning was well worth it.
Bob
Old 03-11-2011, 04:30 PM   #9
Ole34's Avatar
True.
Bob
thats the key right there......i like to clean my brushes frequently also before they get all jacked up
Old 03-11-2011, 04:32 PM   #10
Gymschu's Avatar
Rewards Points: 232
True.
Bob
Bob, if you're doing that much painting, you may want to invest in some more brushes!
Old 03-11-2011, 07:45 PM   #11
Rewards Points: 530
I will wash my brushes a few times during the day to keep them fresh and flexible. No drying of paint on the brush or toward the heel.
I will rinse my brushes in thinner and or water then give them a spin between my palms or sling as much out/off as I can, if I am where I can sling them. I do not leave enough in them to cause the paint to run down my arm. If it starts that, it is time to wash or change brush.
Old 03-11-2011, 09:25 PM   #12
Ole34's Avatar
Originally Posted by boman47k View Post
I will rinse my brushes in thinner and or water then give them a spin between my palms or sling as much out/off as I can, .
you ever bang the tip of your shoe with the brush ??? works great but do it outside
Old 03-11-2011, 09:32 PM   #13
"Preconditioning" helps to get the brush flowing faster. It will draw the paint into the resevoir in the heel faster which is what the brush needs to function properly and fully. It does eventually mix into the material but by then it's done its job and probably does little to make cleaner easier. If paint runs down your arm, try crochet, it's safer. The same concept applies to roller covers. Wetting them helps to wick the paint into the center of the cover, which is where it needs to get to. That's why a dry roller takes some time to start producing, which is the point in time where the inexperienced crush the nap. In fact, at one time they used to put those instructions on roller covers, wet, spin, then dip. Newer low voc paints require more brush cleaning throughout the day. Wire brush the paint from the ferrule, being careful to avoid damaging the ends of the bristles.
Old 03-11-2011, 09:33 PM   #14
Just make sure you wipe your feet well, lest you put one half of a size ten print in the color of the day on the customer's carpet.
Old 03-12-2011, 07:02 AM   #15
Rewards Points: 530
Actually, I'm more likely to spin them in a fiver. I was slinging one in a backyard a few days ago, and I noticed I was getting splatter all over my shoes and pants.
I seldom use oil paint. I do use oil primer and was just doing a little priming. I have a coffee jug that I cut a slit in the top for the handle to go catch on leaving the brush tip just off the bottom so the primer will drain as the thinner removes it and not collect on the brush tip. I took it out, gave a sling or two. Got some spotted Nikes for my effort.
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 11:33 PM
question compressor based air painting racebum Painting 0 04-14-2010 05:34 PM
Painting linoleum floor? Shadow662 Painting 4 11-21-2009 12:21 AM
oil vs water poly batwoman Flooring 6 09-30-2008 11:00 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
