Oil Based Paint Vs Spray Can Paint - Painting - DIY Chatroom Home Improvement Forum
Old 09-07-2013, 02:46 PM   #1
Rewards Points: 337
Oil based paint vs spray can paint
I am going to paint an old file cabinet, semi gloss black. I was thinking of rattle cans but I alway get the lines when painting large areas. Then I thought what about rolling on a semi gloss oil based paint with a foam roller. Will the rolled on oil base paint dry as hard as the spray can paint? I assume so as they are both oil based. Rolling would also be a lot easier with less mess.
titan7 is offline   Reply With Quote
Old 09-07-2013, 02:59 PM   #2
Rewards Points: 4,796
Spraying gives you the finest finish. What kind of "lines" are you getting? There shouldn't be any.
jeffnc is offline   Reply With Quote
Old 09-07-2013, 03:09 PM   #3
Rewards Points: 337
Sort of like horizontal and vertical lines, I can never get a perfect finish with large areas with spray paint. Most of the surface looks good but there always seems to be an area that seems to have better coverage, think like a tick, tack, toe board.
Old 09-07-2013, 03:27 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Try backing off a bit with the spray.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
ToolSeeker (09-07-2013)
Lead Paint Follow-Up RoughDraft Painting 24 06-18-2013 07:31 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Lead based paint jenikahula General DIY Discussions 3 03-10-2009 12:08 PM
Oil, Latex, Acrylic... How to Choose? Turkmenbashy Painting 4 01-18-2009 11:30 AM
