Oil Based Over Floor & Deck Enamel - Painting - DIY Chatroom Home Improvement Forum
Old 09-09-2009, 10:32 AM   #1
Rewards Points: 77
Oil based over Floor & Deck enamel
Hi,
I rebuilt a front porch with 3/4" tongue and groove a month or so ago. Someone recommended that I first apply an oil based primer, which I did. Then I went with SW's. My opinion is that the stuff is junk. It got dull pretty quickly and scruffs easily. Out of desperation, on Labor Day, I went to Lowes. There is one guy there that has decent product knowledge. Because of the VOC laws in PA you can't get decent oil base floor and deck paints. At least that is what he reported. He suggested - not with a lot of enthusiasm - Olympic's Fast Hide Ultra, which is an alkyd. I went ahead a got a gallon.
My question is do I have to put down an exterior based primer over the current SW floor and deck enamel before I apply this Olympic product?
Thanks very much.
Dick
RMCarner is offline   Reply With Quote
Old 09-09-2009, 04:54 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
If the SW was oil, you don't need to prime. Just a scuff with some sand paper will be fine.
Old 09-09-2009, 06:07 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
I am not clear as to what was junk, the primer or whatever you used for a finish coat? No regular paint is going to work on a porch, you need a deck paint,preferably oil. Here is what I would use Ben Moore
Alkyd Porch & Floor Enamel
Urethane-Reinforced Interior/Exterior 112
Old 09-09-2009, 07:08 PM   #4
Rewards Points: 77
Thanks. I'll check out a local dealer.
Dick
Is water based enamel permeable? nerd_flanders Painting 5 08-07-2009 08:54 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Second coat of oil based deck stain? cgoll Painting 4 05-04-2009 02:47 PM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
