Oil Based Enamel On Acrylic Latex? - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 12:09 PM   #1
oil based enamel on acrylic latex?
Hello. I have an outdoor business sign that I have painted with acrylic latex paint and primer in one, and I was wondering if the rustoleum oil based enamel that I got for the details of the sign would stick to the base paint?
cjgbev is offline   Reply With Quote
Old 02-26-2012, 12:29 PM   #2
Too Short? Cut it Again!
No such thing as paint and primer in one. But you get to remedy at least the underlay layer for the lettering with a coat of nice alkyd primer over what you have. Alkyd is the great equalizer. You can use either oil or latex/acrylic over alkyd. You can use alkyd over oil or water based products.
You can actually detail and letter over what you have done but probably not with regular rustoleum enamel products.
Alkyd resin based sign painters enamel, like "One Shot" are a little stickier than regular paints and they will stick to glass and plex without "crawling". If your paint store does not have them an art store will. One shot comes in just about any color you can imagine and you can also mix them to make your own. They are solvent based paints so you will need mineral spirits, paint thinner, etc, to clean your brushes. And use good ones or all is lost.
Old 02-26-2012, 07:03 PM   #3
Rewards Points: 384
Yes. Make sure the surface is clean and it will stick fine. Actually, I'd be more concerned about the latex paint and primer sticking to the surface than the Rustoleum sticking to the acrylic. It'll work fine.
ric knows paint is offline   Reply With Quote
Oil/alkyd over acrylic latex porch and floor enamel balifornia Painting 8 08-16-2011 01:20 PM
Interior vs. Door and Trim Paint HAM_DIYer Painting 5 11-08-2010 12:41 AM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 11:33 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Acrylic Latex Primer vs Latex Primer Saintt Painting 1 08-02-2008 10:00 PM
