Oak Table Refinish Question - Painting - DIY Chatroom Home Improvement Forum
Old 07-19-2013, 04:18 PM   #1
oak table refinish question
In the past I would refinish my dining room table by sanding it down to bare wood, staining it, polyurethane and that's it. I did however just buy an old oak table that has a great surface but is faded, water rings, light scratches etc. it needs refinished badly. The question I have is- the wood is that parquet-type pattern where the grain goes in several different directions and someone mentioned to me to strip the surface with chemicals vs. sanding since you should sand in the direction of the wood grain. I want to know if the stripper is a good choice, will it get the poly and old stain off completely so I am down to bare wood? I have never used it so want to know what to expect. Also what brand is good? Thanks in advance!
annie68164 is offline   Reply With Quote
Old 07-19-2013, 04:33 PM   #2
Rewards Points: 274
There are some good quality available, get anyone, would be beneficial.
alexjoe is offline   Reply With Quote
Old 07-19-2013, 07:53 PM   #3
Rewards Points: 16
Strippers are the way to start
In general, it's better to strip the finish rather than sand. It's easier, cleaner, and gets you to a known surface more easily.
I tend to like using Soy Gel, but there are other good products on the market.
The strippers won't remove stain from your finish, but you may have color removed depending on how much the old finish yellowed over the years, or if a toner was used originally. If you need to remove stain, you can try a bleach formulation, or you might have to resort to sanding.
Trekker is offline   Reply With Quote
Old 07-19-2013, 08:14 PM   #4
Jmayspaint's Avatar
Rewards Points: 534
Sanding in the direction of the grain is very good advice. Cross grain sanding is a generally no-no on any stain grade wood....
But, when you sanded down your other tables what did you use? An orbital probably, unless you hand sanded in the direction of the grain through the finish all the way to bare wood, or used a belt sander.
Sanding with an orbital, even though it doesn't technically go with the grain, isn't the same as cross graining by hand or with a belt sander.
Done right, with the right grit paper, you can use an orbital on parquet without cross grain scratches being a problem. If it has scratches and dings, stripper won't fix that, so to make it nice you will have to sand even if you strip it first.
Using stripper still might be desirable, as it could cut down on the amount of sanding you would have to do. Most strippers will darken the wood also.
Jmayspaint is offline   Reply With Quote
Standard or Sliding Mitre Saw? Or table saw? 7.62 Tools 18 05-07-2012 09:53 AM
Sizing Motor Branch Circuit Conductors and OCPD's electures Electrical 5 06-23-2011 12:32 AM
electrical johnx Electrical 29 06-22-2011 07:52 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Craftsman Table Saw Question TonyCooper Tools 2 12-01-2006 09:44 AM
