Oak Furniture, Want To Paint It White - Painting - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 06:07 PM   #1
Oak furniture, want to paint it white
The furniture is oak with, I think a stain and a finish that has a bit of shine to it. I would like to paint these white and have that smooth finish to them. What kind of paint and what kind of prep do I need to do before I paint. I know I can hear my Dad saying you want to paint oak!!!! Yes I do.
Truffell is offline   Reply With Quote
Old 03-10-2011, 06:25 PM   #2
Learning by Doing
Leah Frances's Avatar
Oh, the voices of our Dads.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-10-2011, 07:02 PM   #3
Gymschu's Avatar
Rewards Points: 932
Don't paint the oak. It never looks right to me. Why not refinish it?
If you're hellbent on paint, you"ll have to sand, tack off the dust, prime with an oil-based bonding primer, let dry, sand and dust off again, apply first coat of white paint, let dry, sand yet again, tack off dust, apply additional coats as needed. Once painted, oak, being a hardwood is easily chipped if you knock into it with something or drop something on it. I say refinish......NO PAINT.
Old 03-10-2011, 07:42 PM   #4
the Musigician
DangerMouse's Avatar
You CAN just spray paint it white with no preparation whatsoever.
It's been done before and will be done again. As to how it will look or hold up.... well....
DM
Old 03-10-2011, 08:16 PM   #5
Rewards Points: 258
Hey Truffell,
You want to paint Oak??!!! I'm a dad, I couldn't resist. Follow what Gymschu said, but to add to what he suggests I would say to prime it with Sherwin-Williams "Wall and Wood" enamel undercoater. It's oil base and drys slowly giving it a chance to bond with the substrate while leveling out, eliminating brush marks. Finish it using a good quality oil base enamel with "Flotrol" added to further allow the enamel to dry without brush marks.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 03-10-2011, 08:43 PM   #6
Originally Posted by spraygunn View Post
Hey Truffell,
Excuse me Steve, I know you know this, but don't you mean "Penetrol". I feel funny correcting my elders lol (inside joke).
Old 03-10-2011, 08:51 PM   #7
Rewards Points: 258
Thanks jsheridan,
What was I thinking? I was probably having a senior moment. I didn't have my nap today, that's happy hour at my age.
Thanks again J
Best of Luck
Steve
Old 03-10-2011, 09:25 PM   #8
Learning by Doing
Point of fact? Floetrol = latex. Penetrol = oil. ?
Old 03-10-2011, 09:47 PM   #9
There is a few different ways to do it. Some are easier and some are harder. What I would do would depend on how fancy the chairs are. If they have a lot of hard to sand areas or not. If not, then I would sand them with a sander using 220 grit paper. You just have to remove the gloss and any bumps or imperfections in the finish. For those hard to get places I always use a sanding sponge.Then clean them well and paint a coat of Zissner primer on them. Sand the primed surface with a really fine grit. I use 600 or finer, just to get any dust or bits off. I then paint with the highest quality furniture paint I can get. Usually Moore. Because you are going white One coat will cover completely but I would put a second really thin coat on. Again sand with the ultra fine between coats. It's not necessary but you could then finish it off with lacquer. I have put up to 20 coats on some of the pieces I have painted and polish them with a 2000 grit wet paper when I'm done. Amazing results I must say.
The other option especially if the chairs are fancy and hard to sand is to buy a product called"Liquid sandpaper". It's amazing stuff and years ago I had a big bookcase that was made out of something that looked like arborite,YUK. Any way, I used the liquid sandpaper on it, no actual sanding at all and then primed and painted it. I still have it and it's still perfect after all those years. I'm actually going to paint it in the next couple of days for a new colour.
Use only water based paints. They are as durable as oil now and much easire to use. AS much as is possible I always paint furniture using one of those small foam rollers. It's easy to get a very uniform coat with no brush marks. For really big pieces I spray them.
I also have had people say,"You painted those nice old wood pieces. you'r crazy". They say that until they see the finished product and then they say,"Man that is beautiful". LOL
lucknow is offline   Reply With Quote
Old 03-10-2011, 09:48 PM   #10
Super Master Painter
Ole34's Avatar
sometimes i use ''Aquatrol''
Ole34 is offline   Reply With Quote
Old 03-10-2011, 10:08 PM   #11
Just think of when I am gone and someone get this dresser after its painted, they will find a treasure underneath. Lucknow, that is just way to much work. I like the spray paint idea, have to do this in my condo. Sorry guys I am not fond of the real wood look. What about the product you wipe on and off then paint with primer than winwax??
Old 03-10-2011, 10:33 PM   #12
Rewards Points: 258
Thanks Truffell you made be feel better. I think that's Minwax not winwax. See I'm not the only one who screws up. Or is there really a product called winwax? If so, I still screwed up.
Best of Luck
Steve
Old 03-10-2011, 11:34 PM   #13
Spraygunn, glad to help, yup minwax, So will that work? I only paint a few times a year and its always walls. I did a coffee table, yes oak and it's now white. The area is very small so looks good. Need help for the large area's. Thanks everyone, great site.
Old 03-11-2011, 08:03 AM   #14
Rewards Points: 258
Hey Trufell,
Stay with what I suggested earlier except use Penetrol instead of Flotrol.
Best of Luck
Steve
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
What colour to paint my white and black bathroom LindaC Interior Decorating 6 01-07-2009 05:59 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
