Old 10-12-2011, 05:08 PM   #1
Oak cabinet does not stain after sanding
Hi Guys,
Bought Home Depot Oak front face unstained kitchen cabinets. Two doors had glue on them that I found out after staining. I completely sanded down the door piece that had glue on (complete section, not just small area) using 80 grit sand paper. I removed all the sanding dust using lint free cloth. Then I applied stain and I do not get any stain penetration . Compared to the rest of the cabinet, the sanded area is 2X lighter in color. I am using Minwax English chestnut stain. What do I need to do to fix the problem? So far this is what my research yielded me
1. Sanding burnished the wood and removed spores from Oak. What can I do to get spores back?
2. There is sanding dust remaining. I need to use tack cloth to remove the dust.
3. I need to dry the cabinet in the sun.
Any other ideas? Should I sand with 40 grit paper instead of 80?
samotlietuvis is offline   Reply With Quote
Old 10-13-2011, 12:33 AM   #2
I'm just guessing but after you sanded the dust could still be trapped in the spores despite using a tack cloth. If you have an air compressor blow it down really well. Or you could simply add more coats of stain until it matches
Dwillems is offline   Reply With Quote
Cabinet sanding & restaining lubenn General Discussion 2 01-20-2011 09:42 PM
I need to stain cabinet but wood varies from light/dark smally Painting 3 06-04-2010 06:21 AM
Looking for suggestions on kitchen cabinet stain color.....pictures attached Rhizzlebop Interior Decorating 15 04-05-2010 03:43 PM
Need Help. Having trouble sanding darker stain from staircase Timotay Flooring 7 10-26-2009 01:53 PM
