-   -   Oak cabinet does not stain after sanding (http://www.diychatroom.com/f4/oak-cabinet-does-not-stain-after-sanding-119942/)
samotlietuvis 10-12-2011 04:08 PM
Hi Guys,
Bought Home Depot Oak front face unstained kitchen cabinets. Two doors had glue on them that I found out after staining. I completely sanded down the door piece that had glue on (complete section, not just small area) using 80 grit sand paper. I removed all the sanding dust using lint free cloth. Then I applied stain and I do not get any stain penetration :(. Compared to the rest of the cabinet, the sanded area is 2X lighter in color. I am using Minwax English chestnut stain. What do I need to do to fix the problem? So far this is what my research yielded me
1. Sanding burnished the wood and removed spores from Oak. What can I do to get spores back?
2. There is sanding dust remaining. I need to use tack cloth to remove the dust.
3. I need to dry the cabinet in the sun.
Any other ideas? Should I sand with 40 grit paper instead of 80?
Dwillems 10-12-2011 11:33 PM
I'm just guessing but after you sanded the dust could still be trapped in the spores despite using a tack cloth. If you have an air compressor blow it down really well. Or you could simply add more coats of stain until it matches
