Nursery Mural - How To Paint Even Black Lines? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-21-2009, 07:52 PM   #16
the Musigician
DangerMouse's Avatar
exactly why i used markers on spidey. the blue and red and other colors were paint.
DM
Old 05-21-2009, 07:56 PM   #17
Rewards Points: 150
What about acrylic paint pens?
johnnyboy is offline   Reply With Quote
Old 05-21-2009, 10:52 PM   #18
Wicked deck Johnnyboy.
Did you spray paint it first?
Prangley is offline   Reply With Quote
Old 05-24-2009, 10:43 PM   #19
I purchased the big Magnum Sharpie and some smaller ones as well.
It is not as easy as I would have liked to believe it to be. The marker seems to produce worse lines the lower it gets. See attached file for example. I have a lot of touching up, filling in and darkening to get a complete line.
I just wanted to mention this for anyone else interested in trying this technique.
G'night!
Old 05-25-2009, 12:01 AM   #20
Registered User
Rewards Points: 5,462
For anyone interested, when you mention specific books and titles, and show it on the web, isn't that plagiarism or using copyrighted material punishable by $2500--$25,000?
http://www.rbs2.com/copyr.htm
Just trying to keep everyone safe here. I may be wrong.......... Be safe, G
Gary in WA is online now   Reply With Quote
Old 05-25-2009, 01:10 AM   #21
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
read about the doctrine of fair use. That will take care of some of your concerns.
http://www.copyright.gov/fls/fl102.html
As to what is happening on this particular thread; is the image an exact copy of some of the artwork? If so, then yes, it could be construed as a copyright infringement but since the poster is not using it for a commercial purpose and not for commercial display, chances are there would be no action sought against them. They may even fall under the doctrine of fair use even if it were exact. It is a grey area and the only place it ever really gets decided is in a court room. I do not think the OP has anything to worry about here.
Now, if they were painting these as a business; most definitely a problem.
Old 05-25-2009, 06:28 AM   #22
the Musigician
prangley: what type paint did you use? i used high gloss enamel for spiderman and had very little touching up like you seem to have to do.
is that flat or semi-gloss?
DM
Old 05-27-2009, 04:36 PM   #23
As was mentioned before, it's for personal enjoyment in my own home and not for profit in any way. So I am not concerned.
I used Para Ultra acrylic latex semi gloss.
I suspect I am also running into this problem because of the shaddy nylon brushes I used where the different colours meet.
Old 05-27-2009, 09:39 PM   #24
nap
You talking to me?
nap's Avatar
I do not believe you have anything to worry about but the other poster is correct in his thoughts. This is a good forum and I believe he was just trying to remind folks about remaining legal.
be sure to post a pic when you are done.
One thing I was thinking was a perfect line would look, well, perfect. Since the style is obviously intended to be imprecise, precision would be out of place.
I still think a round brush would be the way to go. A bit of practice and you would be Picasso redux.
Old 10-05-2009, 03:10 PM   #25
I've been researching the web for awhile now preparing to do our dr seuss nursery and I came across 2 people who suggested using these...
http://www.dickblick.com/products/de...paint-markers/
artistic april is offline   Reply With Quote
Old 10-05-2009, 03:41 PM   #26
Too Short? Cut it Again!
You might try a pinstriping brush for this. It will take a little practice but painting lines is what the things are made for.
They also make little pinstriping rollers set-ups that will do either single or parallel lines. Try an art supply store or check with an auto finish supply company.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Dark to light/neutral couchguy Painting 3 06-20-2008 12:07 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
