Number Of Coats?? Sw Ceiling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 04:54 PM   #1
Rewards Points: 89
Number of coats?? Sw ceiling paint
My question, how many coats of ceiling paint is needed, it was rolled, with a shoreline roller 3/4 nap?
The story is my dad primed my addition with kilz premier, premium. And he did this about 30-45 days ago. I'm building this house and when I get time I continue on each phase. Anyway so I used the sw ceiling paint, nice stuff but shows streaks and different colored areas, this was new drywall. Anyway kilz stated they have a cure time.'after 30 days or so it doesn't take paint to well. It doesn't say that on the package anywhere. Just wondering how many coats of rolled quality paint is the normal.
Chip
Baltimore
chipraynor is offline   Reply With Quote
Old 12-27-2011, 05:00 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
One coat of primer and two coats of paint is standard. Maintain a wet edge and apply your second coat of ceiling paint in the opposit direction of the first coat. If your using SW Brillance it is good stuff, but will need two coats, especially on a new ceiling.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
chrisn (12-28-2011)
Old 12-27-2011, 05:24 PM   #3
Rewards Points: 89
Yes, it's nice but I'm a diy'er so I don't know bad paint. I use what others here recommend.
Thanks fir your help!
Old 12-27-2011, 08:22 PM   #4
Gymschu's Avatar
Rewards Points: 842
Chip, HPNY is correct. Prime and 2 coats. It used to be that SW had ceiling paint that covered in one coat, but, they reformulated and now it takes two.
The Following User Says Thank You to Gymschu For This Useful Post:
housepaintingny (12-27-2011)
Old 12-27-2011, 08:31 PM   #5
Rewards Points: 616
The old classic 99 was better. For res repaints I use Promar 200 flat, lay it on well and usually one coat covers and looks great.
Gymschu (12-28-2011)
Old 12-27-2011, 09:02 PM   #6
Too Short? Cut it Again!
Pro painter's gospel. Primer and two finish coats.
That said? You do bring up a key point in your post. Especially with latex and acrylics. They need cure time before you can really judge them. Although I must admit I never saw Kilz primer begging for 30 days. I haven't actually read what is printed on the side of a can of paint in many, many years.
You may be trying to race the chemistry of your paint? Let it dry.
Anyhow, I think you might find that some of what now seem like paint imperfections disappearing on you over the the next month. Patience. There is something very zen about watching and waiting for paint to dry. So I am told.
One painter on this site will be all over me in seconds because I love big fat roller covers for some things. He will not even try them for the work I use them.
But why would you use 3/4" nap for the ceiling of primed, flat, new construction ceiling? Is it textured in some way you did not share? It seems like too much paint.
Old 12-27-2011, 09:41 PM   #7
Learning Things Every Day
Jay 78's Avatar
Opposite as in perpendicular?
Under Construction
Jay 78 is offline   Reply With Quote
Old 12-28-2011, 04:05 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Just to be clear, I tend to use 3/4 on all walls and ceilings, but not any trim work. If it works for you, great. I have nothing against it, but anything more than 1/4 on trim is not for me. In fact it is a rare occasion to use any roller on any trim work,I tend to use a brush for all cabinets, doors, and trim.
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Question on Paint Sheen for Ceiling Medallion Twister Painting 9 05-18-2011 11:44 PM
Blotchy ceiling using Glidden tinted ceiling paint dshrewsbury Painting 2 12-04-2009 03:41 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Taking paint OFF the ceiling! anniegoff Painting 3 04-16-2007 04:09 PM
