Not Understanding How To Use Graco XR9 - Painting - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 03:20 PM   #1
walt1122
Rewards Points: 334
Not understanding how to use Graco XR9
Hi picked up a used Graco XR9 sprayer that had been poorely cleaned and was all gummed up with latex paint. Also found a defective pressure control unit that I replaced. Unit seemd to run OK but but hard to prime and think i'm needing to make the paint too thin in order for pump to be able to spray out of the gun. Getting a fine mist using a 515 but think I should be seeing a stronger spray? Also, when I shut down, what do I do with all the paint in the hose?? Am I missing something on the care and use of this sprayer. Looked at the comany website but didn't see anything mentioned. Hate to think I just clean all the paint from the hose. Got to be a cup or so. Any suggestions or help on what I'm doing wrong or not understaning would be appreciated.
thanks
Walt
walt1122 is offline   Reply With Quote
Old 06-23-2009, 05:04 PM   #2
Kellster
mjkpainting's Avatar
Rewards Points: 77
I am quite sure that your sprayer needs to be repacked. I had that problem in the RX7 and that was the answer. In my case I wasn't able to prime and there was zero pressure. You can buy a repacking kit and I know many people do it. I personally, have never repacked any of my sprayers.
I take mine to a local shop around here that specializes in sprayers and small engine repair. You can look online find a business that services gracco sprayers.
Also you can call Gracco and have them send you a manual. If you look through it, it gives you the setup and cleanup process. It's pretty complex and not just a common sense thing in terms of cleaning.
mjkpainting is offline   Reply With Quote
Old 06-23-2009, 06:54 PM   #3
walt1122
Rewards Points: 334
Thanks mjkpainting, I guess the guy used it more than he alleged if it needs the pump repaired too! Oh well, I think I still may have got a pretty good deal if I can get it to work and use it to paint my new 3 car garage with an appartment above that we just built down here it Tenn. Has Hardy plank siding and I am trying to save money by doing as much work as possible myself. When I have seen professionals like yourself doing the spraying you guys make it look easy but looking at some of the vidoes it may be more of a challenge than I thought!
The one other thing, all that paint in the line that remains after I done painting and I'm about to clean the machine! What happens to it?? Do you pump/drain it out some how or just rinse it out with the water? Seems like there is a lot of wasted paint this way?? Or am I just not understanding this either.
thanks for the help
Walt
Old 06-24-2009, 08:22 AM   #4
Kellster
Rewards Points: 77
Here is the link to the manual for the XR9
http://www.portlandcompressor.com/do...on-309225W.pdf
Yes, the paint in the lines are still good and can be reused.
I'll try to explain how to reuse the paint in the lines:
Have a 5 gallon bucket of clean warm water
Have an empty 5 gallon bucket called your waste bucket
Put the siphon tube in the bucket of clean warm water
Adjust the sprayer to the lowest setting
Take off the spray tip and housing off the gun and put it in the clean bucket
Press the trigger on Spray gun- you are now cleaning out the good paint from the lines into your paint can to be reused
Continue until you start to see a change in color- this means your are starting to siphon water
Then you start the cleaning process by flushing out the lines with the clean warm water into your waste pail.
I'm not sure how good I am at explaining this but hopefully you got an idea
Old 06-26-2009, 02:52 PM   #5
walt1122
Rewards Points: 334
Hi mjkpainting, your explaination is quite clear and I was pretty sure there was a logical way to do it. thanks to you I see how to do it. Thanks for the advice and for the link. The PDF looks like just what I need to get a better understanding of how to work this thing.
Walt
Understanding sensors for data logging Piedmont Electrical 5 03-20-2009 08:33 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
understanding prewire in remodel help needed cmcgraw Electrical 13 09-20-2008 05:19 AM
Noob needs help understanding sub-panels, please! YerDugliness Electrical 14 09-14-2008 11:35 PM
Understanding how to size a circuit conductor gp_wa Electrical 21 09-11-2008 12:49 AM
