Not Sure What I'm Doing - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 03:05 AM   #1
Unhappy
Not sure what I'm doing
Hi I need help please, I'm painting my daughters room for the first time. She has a textured wall and I need to know what the process is to paint it. Do I need to sand it? Primer it? I'm afraid the paint won't saty on I attached a picture that looks exactly like her wall, can someone please help me? Thanks in advance
Mommy 4 is offline   Reply With Quote
Old 01-17-2008, 06:35 AM   #2
Remodeler
MinConst's Avatar
Mommy,
Your wall finish is called knock down texture. It is probably primed already. If it is clean just go ahead and paint. Figure about 25% more paint than a flat wall, use a long nap roller and take your time cutting in.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 01-17-2008, 07:32 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Is it new drywall? Newly applied texture?
If so, then as Minconst stated, it should be primed first, and that is all it should need for preparation before top coat painting.
If you are using a non-nuetral color (darker/brighter)...consider getting your primer tinted to match the top coat paint color. It will allow you to use less coats of finished paint to complete the walls.
Good Luck!
- Build Well -
Old 01-17-2008, 08:50 AM   #4
great advice above. I would suggest a good grade of paint. (go to a paint store not a box store). Flat finish. tell them you have a single knock down on the walls now ( test with a lightly damp sponge and light pressure to see if it has been primed.) if sponge comes back with white on it... you will need to prime. The store should fix you up with proper roller etc...
Big Bob is offline   Reply With Quote
Old 01-18-2008, 05:25 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 488
This means NOT Behr paint
Old 01-19-2008, 12:12 AM   #6
Thank you for all your great advice, it was all very helpful and now I know what I'm doing, I am glad I found this website it is now on my favorites. My walls are ready to be painted. Thank you
