-   -   Is it normal for primer to show thru dark paint on first coat? (http://www.diychatroom.com/f4/normal-primer-show-thru-dark-paint-first-coat-4146/)
Autumnknight 09-30-2006 11:29 AM
I am in the process of painting my exterior window frames around my house. I posted earlier in different threads about caulking and fixing weather checks.
I primed the repaired spots with an oil based white exterior primer. My window frames are two colors, a light green on the outside frame, and then a dark green on the inside frame. When I put my first coat of the dark green over the primer, I could still see the primer thru the green paint. I then tried putting some more paint on the brush, but then it was tending to run in a couple of spots.
So, am I doing something wrong as I am painting? I am using a Purdy brush btw. Or is it normal for white primer to show thru on the first coat? The exterior paint is a water based paint.
Thanks!
Steve
Paintguy26 09-30-2006 11:36 AM
Totally normal...that's why paint manufacturers typically recommend 2 coats. A tip...when using primers, get them tinted to the color your working with, then you wont have a hard time with them showing through! It's a popular trade secret... :thumbsup:
slickshift 10-01-2006 02:20 PM
What brand/line of exterior paint?
Some show more than others, and some don't show at all
Autumnknight 10-02-2006 02:30 AM
After reading one of the other threads about paint brands...I almost hesitate to say....the dark green paint is Behr :huh: ....
I had bought Pratt & Lambert semi-gloss for the light green (since it was highly rated in CR), and then bought Behr semi-gloss for the dark green. (My windows are light green on the outside frame, then dark green on the part surrounding the glass).
I used a brush, and when I applied the dark green, I could see right thru it to the primer. I understood the other post about using tinted primer....but this weekend I realized that even when I painted over the light green (which is already tinted), it showed thru very plainly as well.
It took 2 coats, and in a few spots, 3 coats, to hide the lighter colors completely.
My next can of paint will be Sherwin Williams or Benjamin Moore....
slickshift 10-02-2006 05:31 AM
Yeah that's about right
You can need 3-5 easily with the Behr
If you get it to cover in 2 your doing well
The best covering exterior paint in SW's Duration
Yes, it costs twice as much as Behr
But if it covers in one coat.....well.....
Paintguy26 10-02-2006 06:38 AM
need I say more?:no:
do I agree?:yes:
