#1 |
Nicotine stains bleeding through newly painted ceiling
How can I stop nicotine stains from bleeding through newly painted ceilings? I used TSP on the walls and ceilings before applying a coat of BIN Zissner primer which appeared to work well. The walls have not bled through and look great, but the ceilings in the bedrooms have yellow-brownish nicotine stains bleeding through a coat of the BIN, and 2 coats of Behr ceiling paint. Any suggestions on how to fix this problem? Would another coat of BIN and a different ceiling paint make a difference?
Thanks in advance for any help! |
#2 |
Should have been primed with an oil based primer before the paint.
#3 |
Rubbin walls since'79
For sure you used the Alcohol based pigmented shellac BIN? That usually stops it cold. The only thing I can think is that you had skips or something in the BIN coat that let it get through.
Is it all over , or just in spots? What kind of ceiling- flat/ knock down/ popcorn?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS |
#4 | |
Nicotine stains bleeding through newly painted ceilingQuote:
#5 |
Try this. Just spot an area that is showing with the BIN, let dry (1/2 hr or more) then respot that with your ceiling paint. See if that gets it.
If so repeat over all spots- full coat of BIN if you think that would be easier. Then full coat of ceiling paint. I don't like Behr in general, their ceiling paint in particular- but in this case it is not the problem. If it was going to bleed, it would through any latex product.
#6 |
paper hanger and painter
Every thing brush said is true,but, I would let the Bin dry a couple hours or overnight before apply any finish paint
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
Thanks for your help. I took your suggestion and recovered with BIN and a different ceiling paint and the ceilings look fantastic! Whew. Thanks again.
#8 |
With nicotine, one washing is usually insufficient. Preparation is a RESULT, not a PROCESS. That being said, do what Brushjockey and Chrisn said and you should be fine...
| Display Modes | |
| Paint peeling off Bathroom Ceiling!!! | armen30 | Painting | 17 | 12-08-2011 09:26 AM |
| Painted Basement Ceiling Question | cibula11 | Painting | 11 | 05-04-2011 12:11 AM |
| Removing painted popcorn texture from ceiling | cnielsen4130 | Remodeling | 8 | 10-08-2007 12:21 AM |
| How do I remove stucco from a ceiling painted with oil paint | labnotes | Painting | 4 | 01-09-2007 11:26 AM |
| Retexturing painted popcorn ceiling | kwehnes | Building & Construction | 6 | 01-02-2007 05:36 AM |
