-   -   Nicotine stains bleeding through newly painted ceiling (http://www.diychatroom.com/f4/nicotine-stains-bleeding-through-newly-painted-ceiling-162040/)
RobynSN 11-03-2012 12:11 PM
How can I stop nicotine stains from bleeding through newly painted ceilings? I used TSP on the walls and ceilings before applying a coat of BIN Zissner primer which appeared to work well. The walls have not bled through and look great, but the ceilings in the bedrooms have yellow-brownish nicotine stains bleeding through a coat of the BIN, and 2 coats of Behr ceiling paint. Any suggestions on how to fix this problem? Would another coat of BIN and a different ceiling paint make a difference?
Thanks in advance for any help!
joecaption 11-03-2012 12:16 PM
Should have been primed with an oil based primer before the paint.
Brushjockey 11-03-2012 12:18 PM
For sure you used the Alcohol based pigmented shellac BIN? That usually stops it cold. The only thing I can think is that you had skips or something in the BIN coat that let it get through.
Is it all over , or just in spots?
What kind of ceiling- flat/ knock down/ popcorn?
RobynSN 11-03-2012 12:37 PM
Yes 100% sure it was the shellac BIN primer. It isn't everywhere, just a few small areas. It could be possible that that those areas weren't coated thick enough, I suppose. The ceiling is flat. So a full thick re-coat of the BIN might do the trick? What ceiling paint would you recommend?
Brushjockey 11-03-2012 12:51 PM
Try this. Just spot an area that is showing with the BIN, let dry (1/2 hr or more) then respot that with your ceiling paint. See if that gets it.
If so repeat over all spots- full coat of BIN if you think that would be easier. Then full coat of ceiling paint.
I don't like Behr in general, their ceiling paint in particular- but in this case it is not the problem. If it was going to bleed, it would through any latex product.
chrisn 11-03-2012 04:47 PM
Every thing brush said is true,but, I would let the Bin dry a couple hours or overnight before apply any finish paint
RobynSN 11-06-2012 01:22 PM
Thanks for your help. I took your suggestion and recovered with BIN and a different ceiling paint and the ceilings look fantastic! Whew. Thanks again.
Mr. Paint 11-06-2012 06:01 PM
With nicotine, one washing is usually insufficient. Preparation is a RESULT, not a PROCESS. That being said, do what Brushjockey and Chrisn said and you should be fine...
