Nicotine Ceilings Already Painted - Painting - DIY Chatroom Home Improvement Forum
Old 03-21-2011, 04:56 PM   #1
Handyman
Rewards Points: 512
Nicotine Ceilings already painted
I have been asked to paint a textured ceiling which is HEAVILY nicotine stained. The problem is that the ceilings have been painted twice with a latex paint and the stain obviously has bled through. I figured a couple coats of Zinsser oil base followed by a latex flat should do the trick but I wondered if anybody knew of a primer, equal in stain blocking power but without the heavy, eye burning, sinus clearing, I'm getting high smell.
canadaclub is offline   Reply With Quote
Old 03-21-2011, 05:19 PM   #2
ltd
Rewards Points: 536
just suck it up and do it right ,zinsser oil cover stain . open a window and vent it outside with fan. for nicotine its the only way . the big boxes sell it for about 22 dollars. you can use a old brush and roller cover and pitch when done .dont rush dry times then 1 or 2 coats of latex. p/s one good coat of cover stain properly applied will be fine .
ltd is offline   Reply With Quote
The Following User Says Thank You to ltd For This Useful Post:
Ole34 (03-21-2011)
Old 03-21-2011, 05:54 PM   #3
Love for Construction
<*(((><'s Avatar
If you had caught it before it had been painted, I would tell you to wash it with a TSP solution, rinse and then use Zinnser's B-I-N. That is what we did in the foreclosed house we bought that had been smoked in pretty heavily. Can't even get a whiff of smoke anymore. It was a lot of work washing all the walls, ceilings, and trim, and then having to prime and paint them but it worked fantastic.
-luke-
<*(((>< is offline   Reply With Quote
Old 03-21-2011, 05:55 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
I have always used Sherwin Williams Pro Block over nicotine and other interior stains. I've never had a problem using this primer to block stains. I know some will say different, as they are use to using oil and shellac for stains, but there are some great latex stain blockers on the market.
housepaintingny is offline   Reply With Quote
Old 03-21-2011, 06:17 PM   #5
Super Master Painter
Ole34's Avatar
heres a 20 yr old nicotine ceiling that i had to freshin up for rental ...............in the first pic you'll see what 1 coat of Zinseer Cover Stain can do ...........the 2nd pic is 1 coat of M.A.B Wall Sheild .........2 coat process and it was a done deal
Ole34 is offline   Reply With Quote
Old 03-21-2011, 06:19 PM   #6
Ole34's Avatar
Originally Posted by housepaintingny View Post
I have always used Sherwin Williams Pro Block over nicotine and other interior stains. I've never had a problem using this primer to block stains..
i used pro block a few times and it does kick ass.....and its LATEX......only latex primer ill use
Old 03-21-2011, 06:24 PM   #7
Rewards Points: 616
It is virtually the only primer I use for interior. Unless I was going to paint plaster or a wall that previously had wallpaper on it. I can use problock primer on a ceiling followed by one coat of promar 200 flat and the ceiling will look great.
Old 03-21-2011, 07:13 PM   #8
Handyman
Rewards Points: 512
Thanks all..I will check on the ProBlock tomorrow.
Old 03-22-2011, 04:54 PM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 474
BIN is the only thing that will guarantee blocking nicotine stain
priming entire interior on a nicotine house Bushman Painting 26 04-18-2010 07:13 PM
All surfaces painted with a brush different from surfaces painted with a roller. praktikal Painting 16 04-06-2010 08:45 PM
Covering Radiant Heat ceilings. Hockeynews Remodeling 3 04-10-2009 08:23 AM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 11:50 AM
Retexturing painted popcorn ceiling kwehnes Building & Construction 6 01-02-2007 04:36 AM
