Nibs - Painting - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 08:46 PM   #1
retired guy
igneous's Avatar
Rewards Points: 137
nibs
I hope I used the right word for the "stuff" that shows up on the walls while rolling. I used Duration matte finish over previously painted walls. During the second coat, "rubbery" material showed up out of the paint tray, onto the roller cover, and then the walls. I pick them off, and re roll. I keep the roller covered when I'm not using it from wall to wall. The paint lid is on the can. The only variable is the tray itself, which is uncovered while I cut in another section. There is no skim in the tray. The SW rep said it might be a "batch" problem. I personally don't like the Duration can. It doesn't seal well. Any help to avoid these artifacts from showing up again? Thanks.
igneous is offline   Reply With Quote
Old 09-03-2013, 09:32 PM   #2
Rewards Points: 6,034
Sounds like it may be coming off the roller, try changing the roller cover.
Old 09-04-2013, 06:45 AM   #3
Jmayspaint's Avatar
Rewards Points: 534
Keep the pan covered with a damp rag every minute your not rolling. Paint dries quick in the pan. It's just skinning over on you where it's rolled out thin over the pan.
Jmayspaint is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
ltd (09-05-2013), ToolSeeker (09-04-2013)
Old 09-04-2013, 07:54 PM   #4
retired guy
igneous's Avatar
Rewards Points: 137
thanks
Things are usually a lot simpler than they appear. Covering the tray makes perfect sense. On a side note, the paint poured a little lumpy right from the can. Should have been my first clue. Thanks.
Old 09-04-2013, 07:59 PM   #5
Gymschu's Avatar
Rewards Points: 1,022
Doesn't hurt to strain your paint before using.........
Old 09-05-2013, 05:10 AM   #6
DIY staff
Rewards Points: 7,174
Pick up a strainer bag---if you wash the bag after using,it will last a while=
Gymschu (09-05-2013)
Old 09-05-2013, 07:03 AM   #7
Or save a trip and use an old pair of wife's panty hose, just make sure it's an old pair.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Jmayspaint (09-05-2013)
Old 09-05-2013, 07:06 AM   #8
Jmayspaint's Avatar
Rewards Points: 534
That works, but it causes runs
The Following User Says Thank You to Jmayspaint For This Useful Post:
ToolSeeker (09-05-2013)
Old 09-05-2013, 09:05 AM   #9
If you use a roller for any length of time, bits of dried paint tend to collect along the frame itself and can scrape off into the pan or bucket. I try to scrape off that gunk before it gets too dry and thick to fall off on its own.
MikeEG is offline   Reply With Quote
Old 09-05-2013, 09:23 PM   #10
Rewards Points: 4,796
In the panty hose or on the walls?
jeffnc is offline   Reply With Quote
Old 09-06-2013, 10:47 PM   #11
cdaniels's Avatar
Mudbone would be proud.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following 2 Users Say Thank You to cdaniels For This Useful Post:
Jmayspaint (09-07-2013), ToolSeeker (09-07-2013)
two waste water nibs garden659 Plumbing 2 10-05-2010 01:56 PM
