Newly Stained Deck Problem - Painting - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 08:59 AM   #1
Newly stained deck problem
We stained our deck last year after having it cleaned, supposedly professionally cleaned. The stain is disappearing like its just dissolving. He used a bleach solution. We have stained this deck before with the same stain and it lasted 7 years before it needed to be re-stained. What is happening?
astpeter is offline   Reply With Quote
Old 04-04-2009, 09:05 AM   #2
the Musigician
DangerMouse's Avatar
what brand stain did he use? something from HD, Lowes or Menards type store perhaps?
DM
Old 04-04-2009, 09:12 AM   #3
Cabot Semi-transparent oil. This is the same stain that lasted 7 years!
Old 04-04-2009, 06:05 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
What was used to clean it?
Not that it might be the problem depending on your answer to the above question, but perhaps it may be that Cabot has re-formulated most products to comply with EPA standards, and they are not as good as they used to be
Again, this may be a moot point depending on what was used to clean the surface
slickshift is offline   Reply With Quote
Old 04-04-2009, 07:16 PM   #5
Bleach. We went to VT to get the stain as they haven't been required to change to the lower VOC formulas. So the stain shouldn't be the problem. Literally the stain just seems to be dissolving.
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Deck Confusion Viking2008 General DIY Discussions 4 07-10-2008 03:41 PM
How to fix un-maintained deck? robertr4836 Carpentry 4 04-18-2008 11:11 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
deck questions robphelan Carpentry 6 06-25-2006 06:42 PM
