Newly Painted Exterior Home - Painting - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 10:36 PM   #1
Newly painted exterior home
I just painted my house( got done about 2 hrs ago) and it just recently showered for less than five minutes. The paint was dry to touch. It is water based latex paint. Schwerin williams superior paint. Will this ruin the paint, doesn't feel wet anywhere on it but you never know. the concrete wasn't even completely wet. Any responses will help.
Donald-64 is offline   Reply With Quote
Old 04-08-2012, 10:44 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
It shouldn't be a problem. If the rain was hard enough to re wet the paint- it would run and you would know. Hopefully that wont happen for you for at least 4 hours.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 04-08-2012, 10:47 PM   #3
Any idea about how long it's safe from a big shower? The last rain shower was not even showing up on the radar.
Old 04-08-2012, 10:54 PM   #4
Lots of factors- humidity, temp etc. You just had it wetted, thats a lot like high humidity. Any place that water pooled is getting softened-
Like I said- 4 hours of good dryng will help tons.
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (04-09-2012)
Old 04-09-2012, 06:50 PM   #5
Gymschu's Avatar
Rewards Points: 496
Good advice given so far. If it was a light shower, you should be ok. If the humidity stays high and it stays damp overnight, you may see splotches on your paint finish from where the moisture stuck to the paint film and ruined the gloss of the paint.
Gymschu is online now   Reply With Quote
Old 04-09-2012, 08:14 PM   #6
Rewards Points: 626
some problems you might have is frosting of the paint. What is frosting you might ask? It is were water hit the paint before it is cured and the surfactant comes out it looks like a salt film on dark color paints. but you should be fine!
Nailbags is offline   Reply With Quote
Old 04-10-2012, 10:36 AM   #7
Rewards Points: 394
Most exterior house paints state on the labels that you should not paint if rain is expected in 48 hours. Many premium exterior products will be resistant to early moisture, but a heavy rainfall can rewet a latex paint. Dark colors, which cure slowly, will most likely be affected (blistering, bubbling).
Will22 is offline   Reply With Quote
newly painted drywall looks good but... mjarema414 Painting 5 03-20-2012 06:48 PM
Painting Over Cigarette Smoke PaintedSurface Painting 27 12-23-2011 03:48 PM
newly painted ceiling paint cracking-Help! Basia Painting 1 01-22-2011 03:09 PM
Newly painted wall has dusty sheen mattbb09 Painting 13 03-24-2009 09:44 AM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 12:50 PM
