New Wood Protection - Painting - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 08:46 AM   #1
pwa
new wood protection
Hi to all, Should you paint or seal new construction before installing soffit panels and fascia?
pwa is offline   Reply With Quote
Old 08-20-2011, 10:14 AM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
painting it 1st could make your life easier. However many people would rather complete all the carpentry work in one area first will the staging is all set up.
Millertyme is offline   Reply With Quote
Old 08-20-2011, 10:33 AM   #3
m1951mm's Avatar
Priming all new wood prior to going up will do a couple of things for you. One, protect the wood from water getting into the fibers of the wood. (I would prime all four sides of every piece of wood going up, and if there is an instance where something needs to be recut, make sure to prime the new cut). Two any edge that you caulk you will want that primed prior to the caulking to ensure the caulk will adhere. Caulking raw anything be it wood or joint compound will compromise the effectiveness of the caulk itself. After the wood goes in is the time you will need to caulk so it really does not save that much time for you to do a prior finish coat before installation and the caulking is complete. Just think of the sunrises or sets you will miss,LoL.
If you are using WOOD for your soffits etc, an oil primer will seal the wood (not raising the grain as a water borne primer will do) and in the long run give you a better finished product.
I had all new ruff sawn cedar added to my home over 6 years ago, and with two final coats of Sherwin Williams Duration, it looks as good today as it did when it went up.
Priming is a NECESSARY evil.
Good Luck and Post Pics!!!!!!
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
Gymschu (08-20-2011)
Old 08-20-2011, 11:21 AM   #4
pwa
Sorry, I should have said that I am putting aluminum pannels on a stick built garage and wanted to know if I should seal the wood before covering it up with the soffit pannels? Thanks for the advice!
Old 08-20-2011, 11:29 AM   #5
m1951mm's Avatar
Since the wood is down and primer is cheap and easy to apply on the ground, I would prime the wood even if it is being covered by vinyl. If a caulk joint fails you have added protection.
Mickey
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 01:24 AM
Wood furniture care/ Cleaning (I ?!#?!? up) bli182nk General DIY Discussions 0 05-22-2010 02:31 AM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
Repairing the wood for painting bofusmosby Painting 4 06-17-2007 12:55 AM
