Old 10-19-2011, 08:49 PM   #1
New homeowner needs advice painting over red cedar!!
I like red cedar in the right setting, but the foreclosure I just bought is way out of place in its neighborhood so I have decided to paint it. The house is 12 years old and has cedar lap siding with about a 6" reveal; it was last stained 3-4 years ago and the cedar looks pretty dry. I was planning on priming and painting with a roller, but I have seen conflicting info on what to use for a primer coat. Since it was stained before, I have been told that the oils will continually seep out so I need an oil based primer to seal the stain in. I have also been told that a good latex primer will siffice. I really want to do this right the FIRST time!!! I would greatly appreciate your input! For what it's worth, I plan to prime, then caulk all gaps, then paint with a premium latex topcoat.
More background info:the builder used Tyvek behind it and sealed the gaps with a clear silicone sealant that has mostly detached and peeled. I am a little concerned about how much moisture is behind the lap siding but we have had intense heat (70 days over 100 deg) and very little moisture over the past 2 years.
I will try post a few pictures tomorrow.
70B5Cuda is offline   Reply With Quote
Old 10-19-2011, 09:42 PM   #2
Gymschu's Avatar
Based on what you posted, DO NOT use a water-based primer.........the tannins and oils in the cedar will leach/wick to the surface leaving stains in your paint job. CoverStain primer from Zinsser is a stain blocking/bonding primer that would be better suited for your project although I have seen stains wick through it from time to time as well. Then topcoat with a quality paint such as SW's SuperPaint Satin.
P.S. If the stain looks decent, why not just restain it? That would be the easiest and least expensive option.
Painting rough cedar interior walls teri777 Painting 2 09-29-2011 11:33 AM
We need advice on painting proches betty wilson Painting 3 08-19-2011 01:23 AM
I need painting advice Mufasa02 Painting 2 08-16-2011 02:58 PM
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 10:52 PM
new cedar roof and zinc advice garym112 Roofing 1 01-18-2006 07:25 AM
