#1 |
New drywall -Sherwin Williams Primer
Just about to prime a couple of rooms that have new drywall and mudding. Everything is sanded flat with 150grit using a 500w halogen light on an angle casting a shadow.
I've used two types of primer+paint for new drywall jobs before - ICI Dulux flat and Rona Expressions(really Behr store brand) eggshell. Both of those turned out bad. You could see the texture differences between drywall paper and mud. If you looked hard enough you could easily point out the screw spots. The Behr also left bad roller marks. After talking with many people, the consensus is to go with Sherwin Williams. Stopped by there today and the lady recommended that I buy their "Quali-kote" hi-hiding latex primer sealer. She said it should do what I want, with one coat! I plan to use a light flat color. Any experience with this primer, will it do what I want etc.. |
#2 |
I used their Prep-rite 200. I was probably the best high hiding primer I have used. Not sure about the quali-kote, but most of their paint you really can't go wrong with.
#3 |
Tired, Cold, and Damp
Go with the PrepRite
#4 |
New drywall -Sherwin Williams Primer |
#5 |
I ended up using the Quali-kote stuff as I'm in Canada and not sure if we have the same product list but the results were amazing. Very few surface blemishes, awesome coverage and blending, covered most 150grit sanding scratches. The primer looks so good that I don't even want to paint. I've never been able to say that. Well worth the money.
#6 |
Glad you've had success. Just think of the finished product you would of had using a higher grade primer......having used hundreds of gallons of both, I wouldn't even think about going with the "Quali-kote stuff" on my own project.
I wasn't impressed with it.Sometimes price can decide for us and in the long run.......just remember to use a high grade finish. Usually ya get whatcha pay for. Good luck~ Last edited by Pro Color; 05-20-2008 at 12:41 AM. |
#7 | |
New drywall -Sherwin Williams PrimerQuote:
What didn't you like about the Quali-kote? |
#8 |
All of the Whatever 200,400, and 700 products (PrepRite, ProMar, whatever) will be in the back, as they are typically contractor products.
I use the PrepRite Pro Block Latex as my primary primer, but it is by no means a high-hide product. It comes in handy for the mild stains present on almost any re-paint project. PrepRite Classic is their best primer in their consumer line. If I manage to go through my fiver of Pro Block, I may give the 200 a try. SirWired |
#9 |
Is PrepRite 200 primer still being called the same thing at SW?
I have an entire condo to paint, it's 95% new drywall with 9ft walls... I want a good primer and plan on buying the stuff tonight or tomorrow night! I may start with a gallon, if I'm happy with it, I'll buy the 5g pale(s). TIA, James Last edited by jawadesign; 12-21-2011 at 02:44 PM. |
#10 | |
paper hanger and painter
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to chrisn For This Useful Post: | Gymschu (12-22-2011) |
#11 |
Hopefully you had your primer tinted to be close to what your finish color is............applying a flat over a good primer makes for a very nice job.
#12 |
thanks guys...
alright, which is the thicker of the two primers below? which of the two will give me a thicker foundation with three passes of the roller. the way the BM rep explained it to me was their AQUALOC was a few microns thicker than their Coranado primer, but that's another topic. BM-Coranado or SW-Drywall primer? the BEHR drywal primer seems as if it seals only with three passes, it's coverage is so, so IMO. Last edited by jawadesign; 12-22-2011 at 01:28 PM. Reason: spelling |
| Display Modes | |
| Drywall ceiling: Water Damage, looking for advice | dawho1 | Building & Construction | 11 | 09-13-2010 11:05 AM |
| Toping Compound for texture....before or after drywall primer? | yummy mummy | Building & Construction | 6 | 05-04-2008 11:57 PM |
| Primer Over Drywall | dgoldb1 | Painting | 16 | 03-03-2008 05:37 PM |
| Painting Bare Steel- Sand First or Use Etch Primer? | scott890 | Painting | 2 | 10-11-2007 05:32 PM |
| Porter Paint vs. Sherwin Williams vs. Benjamin Moore | illinikelley | Painting | 6 | 01-03-2006 10:34 AM |
