New Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 01-30-2008, 01:19 AM   #1
new drywall
when spraying a house do you back roll with a bucket of paint or just roll the paint on the walls after spraying
rrisky is offline   Reply With Quote
Old 01-30-2008, 01:13 PM   #2
Painting contractor
Backroll new drywall. It saves a lot of dipping and time.
Thepaintman is offline   Reply With Quote
Old 01-30-2008, 02:28 PM   #3
Workaholic's Avatar
I think i understand what you are asking.
No bucket, just back roll over what you just sprayed. It helps lay the paint down and will reduce fuzz. Is best with 2 ppl. One to spray and another to backroll.
Sean
Workaholic is offline   Reply With Quote
Old 02-02-2008, 02:31 PM   #4
I know when I spray new construction and am looking for some dimple effect I back roll. I usually have a helper when I am spraying ,having my helper do the back rolling. I use a 1/2 to 3/4 inch roller skin depending on the amount of dimple I am trying to have.I also use a telescopic roller extension pole with a 5 gallon bucket.The bucket will have a grid in it to keep the roller from getting to loaded up with paint. Keeping the millage and dimple all uniform and no fat lines. Hope this helps you out.
mark942 is offline   Reply With Quote
Old 02-02-2008, 08:13 PM   #5
Workaholic's Avatar
You really should give the 18" roller a try for back rolling.
Sean
Old 02-06-2008, 11:18 AM   #6
Pro Painter
If you have two people, backroll as it gets sprayed.
If you're going it alone, you'll need a bucket.
joewho is offline   Reply With Quote
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
