New Deck - Spray Vs Roll / Brush Stain - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-13-2014, 11:34 AM   #31
Jmayspaint's Avatar
Rewards Points: 534
Originally Posted by jeffnc
Well, photos can be deceiving, but that last "red" deck looks in pretty good condition to me.
It's wearing well, doing what it's supposed to do.
The original color was a good bit darker, it has faded in the sun. This is the point that I try to do a maintenance coat before they get too bad.
This is a pic of the same deck, taken at the same time, but under a porch where it gets almost no sun. It still looks almost new.
New Deck - Spray vs Roll / Brush Stain-image-2895478626.jpg
Jmayspaint is offline   Reply With Quote
Old 05-13-2014, 12:50 PM   #32
Rewards Points: 398
So this above picture is Cabot after 2 years?
My deck is 100% sun almost all day - so it looks like every other year for me. Does it need to be sanded each re-coat or only the very first time when the wood is new?
How do I know if the Cabot used is the "original formula" or new VOC stuff?
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 05-13-2014, 01:00 PM   #33
Jmayspaint's Avatar
Rewards Points: 534
I'll post the pics again so you can compare.
Both decks are on the same house, done at the same time (2yrs) with the same Cabbot stain. The first pic is under a covered porch and gets very little direct sunlight. The second two pics are an area of the deck that is exposed to direct sunlight all day.
Yes, it makes a big difference how much sun a deck gets. You can see the fading that has occurred on the exposed deck v/s the covered one.
New Deck - Spray vs Roll / Brush Stain-image-2842230988.jpg   New Deck - Spray vs Roll / Brush Stain-image-374634634.jpg   New Deck - Spray vs Roll / Brush Stain-image-654138608.jpg
Old 05-13-2014, 02:25 PM   #34
Rewards Points: 774
Personally and from experience, brushing on is the best way to work the stain/sealer into the wood. Every other year I'd put Cabot Clear Solutions on my deck and fence. It darkens the wood, but doesn't stain it. I'd go with the guy that uses Cabot and brushes.
I'm sure both of them are fine and a 1 yr. warranty is silly on something like this, because that's about how long any product will start to age a bit.
Stain will eventually wear and look like it needs redone more frequently than something like a clear solution or sealer. Sealers are more transparent and they've been said not to protect the wood quite as nicely as a stain would. however....
ANY wood that sits outside and any product that does the same is going to age, wear, and need a considerable amount of upkeep over the lifetime of the deck. That's why some people never want wood decks. If you can do it yourself, you'll save quite a bit of money, because you'll just need a nice day, a brush and some product....no labor charge
cibula11 is offline   Reply With Quote
Old 05-13-2014, 02:57 PM   #35
Jmayspaint's Avatar
Rewards Points: 534
It shouldn't need sanding every time. A good cleaning including scrubbing is usually sufficient for the first few maintenance coats.
If the Cabbot in your area has been reformulated, it will likely say 'Low VOC' on the label.
Old 05-15-2014, 11:21 AM   #36
Rewards Points: 398
I found this site online - is this a good guide?
http://www.deckstainhelp.com/categor...stain-reviews/
It seems Flood rated slightly higher than Cabot? I think Flood is available at Lowes?
Old 05-15-2014, 07:59 PM   #37
Jmayspaint's Avatar
Rewards Points: 534
Yeah, that looks like a pretty good review site to me.
The Flood that is reviewed in the article is a kind I have not seen yet. They reviewed the CWF-UV5 Oil, sounds interesting. I am only familiar with the regular CWF-UV.
Maybe Gymschu has used this new formulation, I know he uses CWF a lot.
http://www.flood.com/pdf/app-instructions-03.pdf
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 11:26 AM
Given these facts... Deck stain DIY or pay professional? tentaguasu Painting 15 09-13-2011 08:59 AM
Removing stain from deck machouinard Painting 20 09-08-2011 09:12 PM
Deck Stain arrghHeadache Painting 1 03-22-2010 09:51 PM
Spraying a deck stain hdansjr Painting 3 04-21-2009 11:36 PM
