Old 03-22-2007, 02:32 AM   #16
Pro Painter
Is it nessessary to prime?
Originally Posted by Hamilton View Post
Absolutely, but he said it was painted...and who knows with what.
joewho is offline   Reply With Quote
Old 03-22-2007, 10:43 PM   #17
made in U.S.A.
Hamilton's Avatar
Originally Posted by slickshift View Post
New drywall?
You could I suppose
Not really the best stuff though
Sloppy as all get out and no "white" what so ever...it's clear
Well that seems strange.....I wonder why no white?
I'll try the S-W store next time we get some drywall work, would you prefer it for skim-coating?
Thanks for the tip.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 03-23-2007, 08:10 AM   #18
Tired, Cold, and Damp
slickshift's Avatar
Not per say, no
But on any ripped drywall, leftover wallpaper adhesive, chalky paint, etc., I use it before skim coating or repair (mud)
All coatings, paint or primer, are a compromise
Adhesion, coloring, scrubabilty, sheen, coverage, leveling, hiding, sealing, dry time, clean-up, sandability...etc...
That's why there's no one primer that's best for everything
When you get into specialty primers, they excel in certain areas but will lack in others
Like pigmented shellac
Super adhesion, rock hard, can seal out just about anything (fire/mold recovery)
But looks blotchy until painted, and doesn't sand well, clean up well, or apply well
Gardz is truly a great specialty primer in that it can turn a soft, fuzzy, chalky, failing, surface, penetrate it, harden it up, help it adhere (it being the substrate, or surface being primed-that's amazing-primers don't do that) and make a surface that would previously have to be removed or covered actually repair/paint-able
I'm assuming the product simply did not pigment well
I don't know for sure, I'm just happy it does what it does
Lol
But as I mentioned, it's also sloppy, and it's not good at leveling either
Sort of like painting with watered down Elmer's Glue
(hey...it could be )
I wouldn't use it on non-problem areas like new drywall, repainting with an extreme color change, or a simple repair area (new joint compound)
There's better products for those applications
slickshift is offline   Reply With Quote
Old 03-23-2007, 09:38 PM   #19
made in U.S.A.
Hamilton's Avatar
Thanks for the info, Slick, we're gonna try it (if I can find it, lol).
Right now we use Cover Stain probably 90% of the time, along with some BINS and 123. It's hard to beat the drying time, adhesion and sandability of Cover Stain.
How many coats of prime require on new drywall? KUIPORNG Painting 23 02-26-2011 07:47 AM
fresh sheetrock, prime? jamesdart Painting 3 02-25-2007 07:22 AM
painting & prep-- Slickshift? sundog Painting 10 01-17-2007 08:32 AM
Do I need to prime first or will 2 coats be enough? candy Painting 3 07-17-2005 03:04 AM
