Is It Nessessary To Prime? - Painting - DIY Chatroom Home Improvement Forum
Old 03-18-2007, 11:09 AM   #1
Is it nessessary to prime?
I just sprayed knockdown on my walls and ceilings that where perviously painted. Do i need to prime everything before i paint or not? Would 2 coats of color work fine without priming
sflamedic is offline   Reply With Quote
Old 03-18-2007, 11:20 AM   #2
Darylh's Avatar
I always prime drywall and texture before painting and apply 2 coats of finish paint. A flat or satin finish looks best on textured walls in fact I always use Ben Moore Ulti Mat.
Darylh is offline   Reply With Quote
Old 03-18-2007, 11:44 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As Darylh said...a good practice is to prime anything that is 'raw drywall' material of 'one kind or another' ...... prior to applying your topcoats of paint.
- Build Well -
Old 03-18-2007, 05:36 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Yup, it's time to prime
slickshift is offline   Reply With Quote
Old 03-19-2007, 10:38 PM   #5
Pro Painter
The knockdown texture is the same as drywall joint compound. It's the same as going with paint on newly taped drywall. You can get away with a self priming flat paint, but it's a cheesy way to go.
Priming is the proper way to go.
joewho is offline   Reply With Quote
Old 03-21-2007, 12:54 PM   #6
made in U.S.A.
Hamilton's Avatar
We prime before AND after doing any texturing or repairs.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 03-21-2007, 07:00 PM   #7
Pro Painter
Texturing actually sticks better to bare drywall.
Old 03-21-2007, 07:32 PM   #8
made in U.S.A.
Hamilton's Avatar
Absolutely, but he said it was painted...and who knows with what.
Old 03-21-2007, 11:06 PM   #9
Yes the room was a finished room that i sprayed knockdown in. I primed and am waiting to pick a color. Question, what would have happened if i did not prime? What primer do you use and why? I used kilz and its as thick as glue, is that how all primers are? Thanks for all of the advise. The room is looking great.
Old 03-21-2007, 11:51 PM   #10
slickshift's Avatar
What Kilz did you use? there's over 1/2 dozen Kilz primers
Some primers go on like Elmer's glue, but usually those are for specific purposes (high blockers, etc...)
Old 03-21-2007, 11:52 PM   #11
kilz2 latex
Old 03-21-2007, 11:55 PM   #12
made in U.S.A.
Hamilton's Avatar
If you did not prime before applying the texture to a wall painted with old oil base paint there could be an adhesion problem.
Applying a finish coat on unprimed texture/drywall will cause flashing and poor adhesion.
flashing : Uneven gloss or color resulting from an unsealed substrate or excessively high or low temperatures during drying.
We use Zinsser primers 95% of the time, Dunn-Edwards the other 5%. It is not unusual for us to use almost as much primer on a job as we use for the finish coats (minimum two coats), especially on houses that have seen major neglect.
Old 03-21-2007, 11:56 PM   #13
slickshift's Avatar
Originally Posted by sflamedic View Post
kilz2 latex
OK
Right product from that line for that application
It's just not a very good primer, that's all
It'll be fine for now, but next time I'd suggest using something else
Old 03-22-2007, 12:04 AM   #14
made in U.S.A.
Hamilton's Avatar
Hey Slick, have you guys ever used "Guardz"?
Every paint store around here shakes their head when I ask for it, it looks like it might be the hot ticket for drywall.
Old 03-22-2007, 12:32 AM   #15
slickshift's Avatar
Oh yeah, it's a real miracle in a can
Try a different paint store
make sure it's a paint store, not a paint department somewhere, there's a big difference
Ben Moore or Sherwin Williams, or a true contractor supplier with quality coatings should have it
...try in the wallpaper section if it's not with the rest of the Zinsser stuff on the paint side
New drywall?
You could I suppose
Not really the best stuff though
Sloppy as all get out and no "white" what so ever...it's clear
But when you've got a problem area, chalky paint, ripped or tearing drywall, 80 year old wallpaper adhesive that won't come off, Gardz is the stuff
How many coats of prime require on new drywall? KUIPORNG Painting 23 02-26-2011 07:47 AM
fresh sheetrock, prime? jamesdart Painting 3 02-25-2007 07:22 AM
painting & prep-- Slickshift? sundog Painting 10 01-17-2007 08:32 AM
Do I need to prime first or will 2 coats be enough? candy Painting 3 07-17-2005 03:04 AM
