Nekked Walls. Need Advice On Proper Prep - Painting - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 02:45 AM   #1
Renovating My Land Yacht
Rewards Points: 616
Nekked walls. Need advice on proper prep
We are rebuilding after Isaac , basically the house is gutted to 4 feet after 3 feet of water. All insulation yadda yadda is being replaced. I have painted many a house and love doing it but have never dealt with nekked drywall or ceilings for that matter.
The top half of the walls are some pretty funky colors (not mine, we had just moved in) and the bottom will be the new stuff. I usually prime and then 2 coats of paint but not sure how to attack this. Do I use gardz on everything then prime the wall and ceiling, or only gardz the new drywall areas only? Does one use a particular primer for new drywall?
As for painting the ceiling I assume its the same process as walls just from an akward angle. The house is split in two with the back half being empty and that way I can paint with concrete floors etc so drips are not an issue. Once the back half is done then we switch to the front half.
Thanks in advance.
Robyn
forcedreno2012 is offline   Reply With Quote
Old 11-16-2012, 03:08 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
If the ceilings were already painted, no need to prime them.
All the rest, prime with a quality drywall primer and apply the 2 finish coats,prime the whole wall. Fresh Start from BM is another good choice
Old 11-16-2012, 03:33 AM   #3
Rewards Points: 616
Thanks Chris, I forgot to mention in the original post that we decided if we are going to have to gut the house then we are going to GUT the house and so we yanked all the older than me ceiling tiles and have the ceilings drywalled as well. Nothing like biting off more than you can chew.
So if I read this right. We prime the new drywall with the drywall primer, then prime all the "omg who chose that dark purple" painted and newly drywall primed walls and ceilings (basically everything but the dog) and then on with the finish coats.
As an aside we just moved down here from martinsburg WV - small world.
Old 11-16-2012, 05:18 PM   #4
chrisn's Avatar
Rewards Points: 614
You got it( the priming part). I was looking at a job in Martinsburg last Saturday, got it too
The Following User Says Thank You to chrisn For This Useful Post:
forcedreno2012 (11-16-2012)
Old 11-17-2012, 01:56 AM   #5
Rewards Points: 616
Gratz on the job...is it painting related?? Have a house up there that's going to need some work in may.
Old 11-17-2012, 02:28 AM   #6
chrisn's Avatar
Rewards Points: 614
Yes it was and I would be happy to look at it in the spring, thanks
Old 11-21-2012, 12:15 AM   #7
Rewards Points: 616
Okay cant find Gardz anywhere down here except home cheapo and that is 30 miles away, is there another option. Can I use the zins sealer/primer combo to seal the furry bits where I have to patch the sheetrock or do I need to take a roadtrip.
thanks
Old 11-21-2012, 05:42 AM   #8
chrisn's Avatar
Rewards Points: 614
It is worth the drive.Get a couple gals while you are there, it comes in handy and will keep.
Proper Prep for oil stain on wall mobiledynamics Painting 4 06-22-2012 08:03 AM
I'm concerned about the moisture build up on the bathroom walls -Any advice? JayBird General DIY Discussions 15 04-07-2009 10:25 AM
need advice of choosing the proper roofing shingle product nc_yella Roofing/Siding 10 11-19-2008 03:49 PM
Need to Join some walls together. Need advice on a couple of things *Pics* J187 Building & Construction 4 05-20-2006 04:45 PM
