Needing Help With My Bedroom Craft Cabinet. - Painting - DIY Chatroom Home Improvement Forum
Old 12-23-2016, 09:53 PM   #1
Rewards Points: 2
Question
Needing help with my bedroom craft cabinet.
Ok here's what I have its a 3 door wooden cabinet. I think it used to be a soda fountain cabinet for a gas station or a small restaurant. There are the straw holders and the 2 solid blocks that used to hold the machine. And there's the drain with the hose but I removed the hose. And there's the trash thingy on top also.
When we moved it into the bedroom it got scrapped up on the side of the counter and the one door. So I was thinking about sanding it down and then painting it or adding wallpaper to the outside of the doors. And then covering the top with shelf paper.
I have some photos of what it looks like.
I have some paints plus I have some wallpaper. And I also want the cabinet to match the filing cabinets. One is brown and one is gray.
I was thinking about applying paper to the cabinet and the 2 filing cabinets so they match. I think that might work but I don't know if I can apply paper to the cabinet or the filing cabinet.
So here are the paints I have a gray called tabby cat gray from valspar.and one called fame and fortune by clark + kensington. But I don't have enough to paint the cabinet and the filing cabinets. But the paper I have enough to cover all 3 things. But I don't know if it will stick I also have a wallpaper glue kind of stuff for the paper for walls also.
I tried to add pictures but it says I need one post to use links. So for pictures I may need to wait a while.
DawnRenee is offline   Reply With Quote
Old 12-24-2016, 09:38 AM   #2
Gymschu's Avatar
Rewards Points: 502
Re: Needing help with my bedroom craft cabinet.
Yes, boost your post count and post the pics. Next to impossible to offer help without any visuals.
Giving us your general location helps us better help you!
Kitchen Cabinet Install. Help with Square hboogz Carpentry 5 05-12-2015 09:22 AM
Finally mounted upper kitchen cabinet to sloped wall! stripedbass Carpentry 7 01-30-2015 02:23 PM
How to install cabinet face gameengineer Carpentry 5 01-07-2015 06:38 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 12:44 PM
