Old 02-03-2008, 06:37 PM   #1
Need tips for installing/painting moulding
I'm just looking for any tips as I've never done this before.
Just finished our renovation, painted all the walls and are in the middle of having the floors refinished. I saved installing baseboard moulding for last. I plan on getting pre-primed from Home Depot.
I don't think you're supposed to tape newly poly'd floors so any tips on protecting them? What if I put paper down under the moulding and then either cut it or pull it out from under it, once painted?
Also: I've got to use liquid nails to attach the moulding, so would it be a good idea to pre-paint, then touchup the caulking afterwards?
BradG is offline   Reply With Quote
Old 02-03-2008, 10:33 PM   #2
Remodeler
MinConst's Avatar
I prepaint molding whenever possible before I installing it. Why can't you uses finishing nails to fasten it, fill the holes and just touch it up? Liquid nails will never get it tight to the wall. If you will need to paint after then the paper is a good idea. Waxed paper would work best as it will slide out from under the molding easily.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 02-03-2008, 10:45 PM   #3
Wax paper, great idea, thanks.
I can't nail because the walls are plaster on concrete. There is a wood strip imbedded in the very bottom of the wall which the old molding was nailed into but the strip and the original moulding are only about 1-3/4" high. I'd like to use a more standard (taller) size for the new moulding.
Old 02-04-2008, 01:44 AM   #4
I agree, prepaint the molding. Liquid nail if required, but I would brace something against the molding to hold it tight against teh wall while drying. Good luck!
leroyme is offline   Reply With Quote
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Moulding options for badly warped wall? marc205 Flooring 4 01-21-2008 08:43 AM
Is it best to caulk new moulding edges before painting? Davo Painting 8 04-15-2007 12:12 AM
Wood Interior On Patio Door with White Moulding tom_patriot Remodeling 3 12-06-2006 06:51 PM
wood moulding farrington135 Painting 2 08-25-2005 12:03 AM
