Need Tips On Cracked Plaster - Painting - DIY Chatroom Home Improvement Forum
Old 07-08-2007, 07:38 PM   #1
I need lots of drywall...
need tips on cracked plaster
I just bought my first home, built in 1938, and all of the walls are plaster and cracks in every room. I do eventually plan on replacing them with sheet rock, but for now I plan on using joint compound and painting over the cracks, but I am afraid that the compound will still show through the paint. Are there any tips to avoid this?
maxshockerflo is offline   Reply With Quote
Old 07-08-2007, 09:58 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Only way to hide the lengthy areas of the patches of compound is to: Do you crack patches, and then skim coat the wall area over to blend and attempt to hide the work.
Other option (which is a permanent repair and is seamless and undetectable (if done right) is to install 1/4" to 3/8" sheetrock over the walls using 1 5/8" dywall screws.
Example of an apartment (walls: old horsehair plaster gone over with 3/8" sheetrock. Dropped grid ceilings ripped out, reframed with new 1/2" sheetrock & new ceiling lighting added):
- Build Well -
Old 07-10-2007, 10:48 AM   #3
I didn't realize that I could install sheet rock over the existing wall. That helps alot. However, I do neet to replace a lot of electrical, but that may still cut down a lot of work. Thanks.
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Damp, Crumbling bricks & Blown Plaster crscrs Building & Construction 2 10-02-2008 06:20 PM
Plaster replacement lburele Building & Construction 1 04-29-2007 10:48 AM
Plaster removal decision Sarai Remodeling 2 09-08-2006 04:15 PM
Cracked Plaster Ceiling..... SSandecki Remodeling 1 12-23-2005 09:16 AM
