need tips on cracked plaster
I just bought my first home, built in 1938, and all of the walls are plaster and cracks in every room. I do eventually plan on replacing them with sheet rock, but for now I plan on using joint compound and painting over the cracks, but I am afraid that the compound will still show through the paint. Are there any tips to avoid this?
Other option (which is a permanent repair and is seamless and undetectable (if done right) is to install 1/4" to 3/8" sheetrock over the walls using 1 5/8" dywall screws. Example of an apartment (walls: old horsehair plaster gone over with 3/8" sheetrock. Dropped grid ceilings ripped out, reframed with new 1/2" sheetrock & new ceiling lighting added): http://i28.photobucket.com/albums/c2...T/IMG_0956.jpg |
I didn't realize that I could install sheet rock over the existing wall. That helps alot. However, I do neet to replace a lot of electrical, but that may still cut down a lot of work. Thanks.
| All times are GMT -4. The time now is 05:18 PM. |
