Need A Taller Ladder - Painting - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 11:12 AM   #1
Rewards Points: 270
Need a taller ladder
I want to clean and screen my gutters but my 14 ft extension ladder is two feet short. I was thinking of bolting some boards or metal of some kind along the sides to make my own extension. Anyone seen something like this or have some ideas on how best to do it?
Was thinking of removing the end caps and using a piece of plywood laminated to a pine board on each side to make the extensions. I did not like the idea of using one single board, in case it decided to split. Maybe using some threaded rod through the rungs to hold them tight?
puttster
puttster is offline   Reply With Quote
Old 03-18-2013, 11:30 AM   #2
Gymschu's Avatar
Rewards Points: 502
I don't think you will get too many responses or endorsements for what you are trying to do. Once you change a ladder in any way, you void any warranties and put yourself at INCREDIBLE risk for injury. Ladder injuries are the #1 jobsite cause of injuries and DEATH.
The Following 6 Users Say Thank You to Gymschu For This Useful Post:
Dave88LX (03-22-2013), joecaption (03-18-2013), jsheridan (03-18-2013), ltd (03-18-2013), mj12 (03-18-2013), Nailbags (03-19-2013)
Old 03-18-2013, 11:37 AM   #3
Rewards Points: 2,516
No have not seen anything like that. If you do rig something up please post a photo.
When I need a larger than the 16' ladder that I have, I brorrow my neighbor's 24'
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Gymschu (03-18-2013)
Old 03-18-2013, 12:10 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
Have you fallen 14'? I fell 5' sideways off a ladder once....it HURT...a LOT. I would not want to fall any further than that.
What you are proposing is the stuff Darwin stories are made of. Time to spend some bucks and get the right size ladder.
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 03-18-2013, 12:34 PM   #5
I wonder whether you need a 16' ladder or you really need an 20' ladder. A ladder should extend 3 feet above the roof.
Dorado is offline   Reply With Quote
The Following User Says Thank You to Dorado For This Useful Post:
mj12 (03-18-2013)
Old 03-18-2013, 12:37 PM   #6
Rewards Points: 13,300
Might want to check on Craigs List someone always has them on sale there under tools.
Do not buy just a cheap homeowners grade ladder. Look for an aluminum or fiberglass class 1A.
Buy a ladder stand off and the stand off can sit on the roof and the ladder will not be sitting on the gutters and be less likly to tip over.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Gymschu (03-18-2013), mj12 (03-18-2013)
Old 03-18-2013, 02:20 PM   #7
Rewards Points: 270
Is there anything specifically wrong with my design? I'd like to know beforehand
Old 03-18-2013, 02:29 PM   #8
Compleatly unsafe!!!
Lets put it this way If I walk up to one of my jobs and saw one of my gu ys had made alterations to a ladder he would be fired on the spot.
If OSHA ever saw someone on a ladder like that the whole job would be shut down.
It just a very very bad idea.
Old 03-18-2013, 02:41 PM   #9
Rewards Points: 258
Not safe. Buy a new ladder. One visit to the emergency room will cost many times the cost of a new ladder. I understand that money may be an issue but if it wasn't the Little Giant ladder is the way to go. Versatile, solid but somewhat heavy. Nope, I don't have stock in the company. Just happy with the product.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
Old 03-18-2013, 02:52 PM   #10
None of us really know that your design would be unsafe. It's just that if you were a professional then you'd be violating OSHA, and we don't know what kind of quality control you have and you probably wouldn't test it as well as ladder manufacturers test their ladders or design it as well to begin with. What you want to do is generally considered unsafe. You'd be better off building a wide 2' high platform, and maybe you could reuse the wood. Maybe people would be willing to help you with that. Nobody here has experience in ladder modification.
Old 03-18-2013, 03:11 PM   #11
And the reason for no one having any experiance altering a ladder anyone that does this for a living would know better then to even try do it.
Old 03-18-2013, 04:42 PM   #12
cdaniels's Avatar
Get a ladder long enough for your needs.Anything else is unsafe.I wouldn't even consider it.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 03-18-2013, 04:51 PM   #13
Not worth the risk, A good heavy duty ladder is cheap compared to the cost of a fall!
Hardway is offline   Reply With Quote
Old 03-18-2013, 05:09 PM   #14
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,024
I say go for it!!
This is what I would refer to as sarcasm.
Do not do this...!!!! Borrow a ladder.
Old 03-18-2013, 05:47 PM   #15
Rubbin walls since'79
Brushjockey's Avatar
I got rid of my taller ladders - didn't want to store them for occasional use. Now I let the rental company store them.
Rent the right one. Not expensive, the right thing to do.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Best Way To Secure Ladder To Ladder Rack? Chris Sweeney General DIY Discussions 12 10-10-2012 08:13 AM
New ladder advice kathyll Building & Construction 4 07-11-2011 12:29 PM
installing a ceiling ladder jerry1967 Carpentry 6 11-21-2006 12:18 AM
