Need To Restore Faded Cedar Siding On Ranch House - Painting - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 06:25 AM   #1
Need to restore faded cedar siding on ranch house
I bought a "ranchette" property recently, The main house is on a concrete slab, and has cedar siding. It was built in 1975, and by the looks of it, its the original finish. Its very faded in some areas. It has some unknown sort of reddish-brown stain on it. The bottom of the siding in a number of areas has dry rot (not really termites), It is only a couple of inches at bottom--- I am told that I need to put 1x4 cedar boards all around at the bottom, and the boards should have a bevel at the top to shed water. So I need to do this first, then tackle the finish restoration. I would like to stay with the same reddish-brown color. I suspect what was used was an oil-based semi-transparent stain. The one time I tried to use a sprayer, it was a disaster, so I would like to get something that I can roll on and back-brush.
Does the old finish need to be stripped? (Don't see how you could since it looks like a stain) Can I put on a preservative, or are stains available for cedar that have preservatives added?
Jimigunne is offline   Reply With Quote
Old 02-23-2010, 12:55 AM   #2
Heritage Restoration
IMO.
I would do this in the spring. Spray on a mixture of Borax and Water on all the low areas that are starting to rot. The Borax kills microbes but is environmentally safe. It also penetrates into the wood to prevent rot in the future (sorry..it doesn't UnDo rot )
I would then let it all dry out totally for a few days.
Then I would coat the shakes in a High Quality Boiled Linseed Oil. Maybe add some stain to the oil to tint it if you like. Should take less than a week to dry totally in the summer.
Skuce is offline   Reply With Quote
Tags
cedar siding
paint or stain weathered cedar siding daynat Painting 1 06-02-2009 10:03 PM
revitalizing cedar siding Fat b Painting 1 04-30-2007 01:29 AM
8" cedar channel siding pedro8238 Building & Construction 2 08-24-2006 01:16 PM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 07:43 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
