Need To Remove Baseboards That Are Glued And Nailed - Painting - DIY Chatroom Home Improvement Forum
Old 10-13-2005, 09:12 AM   #1
Rewards Points: 33
Need to remove baseboards that are glued and nailed
Hi there,
I'm doing some painting and flooring in my house and need to remove the baseboards. Normally I've removed ones that are just nailed on, no big deal. The ones in my house are nailed AND glued on... I took off some in the living room with quite a bit of difficulty because the glue held onto the paint which peeled away at the wall in some places. I used a razor blade to cut when it was pulling really bad. Is there a better way to do this? They are painted press-board baseboards.
Thanks all!
Rick
recklessrick is offline   Reply With Quote
Old 10-13-2005, 03:19 PM   #2
Paperhanger/painter
ProWallGuy's Avatar
You did just about all you can do. Run a razor knife over the whole top edge of all the base before you start to pull it up.
ProWallGuy
Professional Wallpaper & Paint Co.
ProWallGuy is offline   Reply With Quote
Old 10-13-2005, 03:22 PM   #3
Rewards Points: 33
That's what I figured, I'll do what I can then. What's the best stuff to use to patch the wall should a it rip some of the wallboard a bit?
Thanks!!
Old 10-13-2005, 09:13 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
I usually patch with joint compound in a case like that
slickshift is offline   Reply With Quote
Old 10-14-2005, 09:10 AM   #5
Rewards Points: 33
Thanks for the info, I hope I don't have to patch but you never know....
Rick
Old 10-14-2005, 12:46 PM   #6
slickshift's Avatar
Originally Posted by recklessrick
...I hope I don't have to patch...
Exactly
...exactly
If you do need it, you'll probably be able to get away with a 4" putty or taping knife and a small tub of compound
Post back if it's really bad or deep, but I'd be kinda suprised if that wouldn't take care of it
Old 10-14-2005, 04:06 PM   #7
Rewards Points: 33
Good deal, I'll let you know if your tip doesn't do the trick.
Thanks for the great help!!
Rick
Old 10-14-2005, 05:20 PM   #8
Contractor
Sell some new base that is higher as an update, everybody is going 5-1/4" Colonial nowdays.
Teetorbilt is offline   Reply With Quote
Does 5" Hardwood Solid need to be glued down as well as nailed down. reibuild Flooring 2 08-03-2007 10:37 PM
