Old 06-20-2007, 03:58 PM   #1
Need quick response..masking tape
I primed the room yesterday and now ready for the red.
When i pulled the masking tape off, dry, some of the primer came off with it!
Is it better to remove the tape before or after it dries?
If after drying I guess I didnt do a good job taping?
usaalways is offline   Reply With Quote
Old 06-20-2007, 04:13 PM   #2
weekend warrior
I believe you're supposed to remove the tape when the paint is still slightly tacky, so it doesn't pull the paint off as well.
You could run a razorblade along the edge as well now that the primer is dry
johnny331 is offline   Reply With Quote
Old 06-20-2007, 05:49 PM   #3
razor blade! Yes!
I didnt think of that. I will surely do it. As u can see Im not too exeprienced at this.
Thax for the quick reply
Old 06-21-2007, 07:59 AM   #4
Tired, Cold, and Damp
slickshift's Avatar
You are using the wrong kind of tape
You should be using Painter's Tape
(Blue or green)
Also, if possible, don't use tape at all
Painter's Tape is way over-used and way over-rated, and can create way more problems if not used properly
slickshift is offline   Reply With Quote
Old 06-21-2007, 10:57 AM   #5
poppameth
Guest
Posts: n/a
If you are that unsure of you freehand painting skills you can try a small paint shield instead of tape. It'll help you keep a neater line and is removed immediately with no adhesives involved. Just make sure to clean the paint off the edge frequently.
How to use non-adhesive drywall tape? tripower Building & Construction 1 05-28-2007 10:29 AM
Tape for duct work? Willie5566 HVAC 4 01-16-2007 05:02 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 09:28 PM
Repairing where paint peeled off with masking tape? Doug Crf Painting 4 04-29-2006 11:47 PM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
