Old 11-07-2011, 08:52 AM   #1
need a product to patch wood outdoors...
I have some garage door casing that is rotting where it meets the concrete. I've thought about using bondo or wood filler? The casing is about 8" wide. The deteriorated wood is about 3/4" gap at the one end of the casing. Any suggestions?
Thanks in advance for any info
dbldee20 is offline   Reply With Quote
Old 11-07-2011, 09:50 AM   #2
A Little Of Everything
Durham's Rock Hard Water Putty is what I'd try. Truth is, though, it's only going to be a patch - kind of like slathering Bondo on a rusty area of your car. It's a temporary fix. Good luck!
DrHicks is offline   Reply With Quote
Old 11-07-2011, 10:01 AM   #3
Abatron was highly recommended to me when I was looking for a good wood repair solution. http://www.abatron.com/
autx790 is offline   Reply With Quote
Old 11-07-2011, 10:04 AM   #4
I've never heard of it. How did it work - as in, turn out?
Old 11-07-2011, 10:29 AM   #5
Busy DIYer
picflight's Avatar
What would be a recommended permanent fix?
picflight is offline   Reply With Quote
Old 11-07-2011, 11:02 AM   #6
I haven't used it yet. I've been restoring the interior of the house for now. I hear about it through old house restoration forums. Someone also recommended this company as a cheaper alternative
https://ewoodcare.3dcartstores.com/R...sives_c_2.html
Old 11-07-2011, 04:31 PM   #7
Replacing the trim.
Of course, I know that's not always feasible or even desirable.
Old 11-07-2011, 05:23 PM   #8
paper hanger and painter
chrisn's Avatar
This is good stuff. Expensive ,but it works.
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
Help Need Wood identification :D x3 iloveusk8rboi Carpentry 3 10-15-2010 10:05 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 11:56 PM
Engineered wood floor product reccomendations? manjo Flooring 10 04-22-2009 12:17 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
