Need Primer? - Painting - DIY Chatroom Home Improvement Forum
Old 03-25-2014, 07:12 PM   #1
Rewards Points: 18
Need Primer?
I will be painting some bi-fold doors and wondering if I were to use Solo from SW will I need primer to go over the already oil base paint there now? The reason I'm painting them is because they have yellowed over the years. Thanks
Nimnum is offline   Reply With Quote
Old 03-25-2014, 10:58 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
Yes, definitely. A bonding primer.
Jmayspaint is online now   Reply With Quote
The Following 3 Users Say Thank You to Jmayspaint For This Useful Post:
Danahy (03-26-2014), Gymschu (03-26-2014), Nimnum (04-02-2014)
Old 03-26-2014, 03:15 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 128
what he ^ said
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Old 03-26-2014, 08:09 AM   #4
Rewards Points: 5,974
Agree
The Following User Says Thank You to ToolSeeker For This Useful Post:
Nimnum (04-02-2014)
Old 03-26-2014, 07:50 PM   #5
Painting Contractor
Rewards Points: 85
Four sure!
VAProPainter is offline   Reply With Quote
The Following User Says Thank You to VAProPainter For This Useful Post:
Nimnum (04-02-2014)
Old 03-26-2014, 09:50 PM   #6
Painting Contractor CT
Rewards Points: 77
Need Primer?
Agree, you will need primer!
KD PAINTING is offline   Reply With Quote
The Following User Says Thank You to KD PAINTING For This Useful Post:
Nimnum (04-02-2014)
Old 04-01-2014, 08:07 AM   #7
Rewards Points: 18
SW said to use Pro Block which is an oil base. Would you guys use that? I thought we were getting away from oil. Thanks
Old 04-01-2014, 08:10 AM   #8
Gymschu's Avatar
Rewards Points: 230
Use this: Sticks to anything, even glass and, although the smell is strong, it is latex based and much easier to work with
The Following User Says Thank You to Gymschu For This Useful Post:
Nimnum (04-02-2014)
Old 04-02-2014, 02:28 AM   #9
chrisn's Avatar
Rewards Points: 128
no it's not
The Following User Says Thank You to chrisn For This Useful Post:
Nimnum (04-02-2014)
Old 04-02-2014, 09:15 AM   #10
Rewards Points: 18
Thanks...it's kinda confusing because when you call the paint store they tell you different things. One says go with Multipurpose Oil another person says Pro Block Oil which I can't find on the Web site and another says just use Pro Classic alkyd enamel and forget the primer. Would that finish look as good as Solo? Thanks for the tips.
Old 04-02-2014, 05:22 PM   #11
chrisn's Avatar
Rewards Points: 128
The finish would look fine, but if it is white, then it will yellow if you use oil. Plus you have the lingering oil odor. I would prime with the 123 and use the Solo or any other quality finish coat
Nimnum (04-02-2014)
Old 04-05-2014, 10:22 AM   #12
Matthewt1970's Avatar
Rewards Points: 1,098
Originally Posted by chrisn View Post
no it's not
Comes in either oil or water based.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
chrisn (04-06-2014)
Old 04-05-2014, 11:47 AM   #13
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
What type of finish is currently on the doors? semigloss or gloss should be sanded first IMHO. this will help the primer adhere to the paint.
Gregg M.
gmaint is offline   Reply With Quote
Old 04-05-2014, 09:13 PM   #14
Pro Painter
Bi-fold with louvres? I don't see any reason to prime them. Already painted with a good oil paint? Sanding will be necessary either way. Just sand them and use a good top coat. Louvres are such a pain to begin with, why go through the extra step if you don't have to?
joewho is offline   Reply With Quote
Old 04-05-2014, 09:37 PM   #15
If you remove them paint regular way then turn them upside down to finish they are easier to paint.
Gymschu (04-05-2014)
primer and paint questions wengang1 Painting 8 12-01-2013 10:22 PM
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 08:47 AM
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 06:03 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
