Need A Painting Tip - Painting - DIY Chatroom Home Improvement Forum
Old 08-24-2007, 12:22 AM   #1
Need a painting tip
I just found a nice but simple black wooden end table that's a little worn. Do I just use regular semi gloss black paint on this after I finish sanding it or do I need primer as well? How do you get that nice smooth to the touch finish you sometimes see in higher priced furniture?
Krichton is offline   Reply With Quote
Old 08-24-2007, 07:29 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
That depends on what the finish is on it now
Do you know what it is?
I believe the finish you are referring to is black lacquer
slickshift is offline   Reply With Quote
Old 08-24-2007, 09:21 AM   #3
No I have no idea. I'm guessing I wouldn't be very successful doing a black lacquer finish.
Old 08-24-2007, 02:06 PM   #4
slickshift's Avatar
I don't know of a good DIY way off-hand
If you wanted to paint the item, it would need a scuff sanding, dusting/cleaning, and I'd recommend a shellac-based primer/sealer and two coats of waterborne enamel
Old 08-24-2007, 07:59 PM   #5
made in U.S.A.
Hamilton's Avatar
I almost always agree with Slick, but this time I'm gonna differ.
I would recommend using oil base on furniture simply because, in my experience, latex finishes don't dry as hard as oil does; which I think is critical for furniture.
If you spray it with an airless it might turn out to be pretty nice looking.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 08-24-2007, 11:24 PM   #6
slickshift's Avatar
You would be correct, and it's not just your opinion, it's a fact
Todays waterborne enamels are almost as good as their oil-based (alkyd) counterparts, but the durability (and a few other points) still goes to the oils
I wouldn't have a problem recommending either
Old 08-24-2007, 11:26 PM   #7
Pro Painter
Best bet is to use a spray can of black for the top coat. Don't use latex on funiture.
Best to prime, but you can get away with scuffing and painting. Use two coats of spray paint. Sand the primer with a 220 sandpaper (if you prime)and then sand the first coat of paint with 400 or higher grit before spraying the final coat. Another way is to apply a clear coat of desired sheen after painting and sanding with the 400.
The smooth finish comes from letting it dry in a dust free enviornment.
joewho is offline   Reply With Quote
Old 08-25-2007, 01:26 AM   #8
I see 13 oz spray cans of this in my local lowes for $5.50. That's the only I've seen so I'll probably get a can.
Old 08-25-2007, 01:39 AM   #9
Thanks for the advice. What is the significance of paint from a spray can? Isn't that latex paint? Is all the sanding during the painting process necessary to get a smooth finish even if through you're spraying everything on?
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Painting over wallpaper RussellF Painting 8 11-01-2006 01:42 PM
Hairline Cracks after painting parasailing Painting 8 07-23-2006 11:47 PM
Painting disaster - help! amiller73 Painting 2 01-12-2006 01:23 AM
