Old 09-03-2011, 08:31 PM   #1
LTI
need interior plywood wall solution
This cabin has plywood for interior walls. What can I do
with them to cover them up? Paint them? How?
cabin in alaska
LTI is offline   Reply With Quote
Old 09-03-2011, 08:59 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Pretty simple- does it have a finish on it? If so- sand to break gloss, prime with a bonding primer like Zinsser 123,.
fill nails, caulk as needed, 2 coats of a finish like Matte on what would be walls, and what would be trim, step up a notch in sheen to a satin or semi.
Use good material- it's worth it.
Brushjockey is offline   Reply With Quote
Old 09-04-2011, 03:43 AM   #3
Thadius856's Avatar
I'm with Brush on this one. Countersink any nailheads, fill with stainable wood filler, apply a stain. I'd go with a cherry color from what I'm seeing here. But I can't see your carpets.
Finish off with some stained moulding on the edges. It looks like much of it has been covered in quart-round already. Certainly a glossier finish on the trim pieces.
Thadius856 is offline   Reply With Quote
Old 09-04-2011, 10:07 AM   #4
Thad- they don't look raw- i don't think staining is an option.
Old 09-04-2011, 03:11 PM   #5
sdsester's Avatar
Don't look raw to me either and doubt a stain would apply evenly. I would prime and paint. I would use a high build primer to fill in some of the wood grain if that is objectionable.
sdsester is offline   Reply With Quote
Old 09-04-2011, 11:29 PM   #6
LTI
Thanks everyone! I'll probably sand, prime and paint as ya'll suggested. I'll post a pic as I get going.
Not sure what the carpet is going to be yet. The room is about 8 feet by 14 feet.
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
