Need Ideas/tips To Prep The Ceiling Surface For Shower Room - Painting - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 12:15 AM   #1
Rewards Points: 200
Question
Need ideas/tips to prep the ceiling surface for shower room
Hi all, thanks for reading this again.
I have a shower room that had some mildew, after I cleaned it with bleach, I used putty knife to get rid of the loose paint and currently it look like this:
I was trying to sand the surface but it's kind of hard to sand the ceiling using sand paper. Any other ideas or tips about better preping the surface before I put up the 1st coat of primer (Zinsser Bulls Eye 1-2-3)? How much coat of primer do I need? After the primer I'm planning to put up Zinsser Perma White for mold/mildew prevention... Would one coat of Zinsser Perma White good enough?? Thought or comments? Thanks!
ohman is offline   Reply With Quote
Old 09-25-2012, 03:28 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 310
Skim with joint compound , sand smooth, clean the dust off, repeat as needed.
1, one coat primer
2 two finish coats
Old 09-25-2012, 08:09 AM   #3
Too Short? Cut it Again!
What Chris suggests works for me^^
Old 09-25-2012, 08:37 AM   #4
Rewards Points: 13,450
Anyone else notice the illegal light fixture in the shower area?
It needs to be replaced with a water tite shower fixture.
Old 09-25-2012, 12:12 PM   #5
Rewards Points: 200
1, one coat primer
2 two finish coats
Thanks for the tips. As it's a tight space and it's the ceiling, I really had hard time to really sand it with a plain sandpaper. Is there any tool I can use (power sander, etc.?) that I should consider using to make the sanding process easier? Thoughts or comments? Thanks!
Old 09-25-2012, 05:12 PM   #6
chrisn's Avatar
Rewards Points: 310
Maybe it's a temporary work light
Old 09-25-2012, 05:13 PM   #7
chrisn's Avatar
Rewards Points: 310
Just a block sander by hand is all I use.
Old 09-25-2012, 06:12 PM   #8
Good point Joe but I cannot tell from the pic. It almost looks to me like the fixture is fine but it has the wrong bulb in it. It should have a flush fitting flood if I am seeing it correctly. Good to point out it will cause problems in short order the way it is being used.
Old 09-25-2012, 06:15 PM   #9
You going overboard on this? You want to sand your patches and if you laid them on too thick I guess you pay the piper. If you are just scruffing up the surface for adhesion you do not have to attack it so severely. Just add some tooth.
A pole sander can help working over your head but if you are up on the ladder anyhow and it is a small space? Just use a sanding block or one of the 3M sanding sponge things with the finer side, if it has two.
Old 09-26-2012, 10:32 AM   #10
Rewards Points: 5,974
the thing I would add is wet area I would do oil based at least the primer.
Old 09-26-2012, 01:17 PM   #11
Rewards Points: 200
I just checked and noticed that Zinsser Bulls Eye 1-2-3 is water-based primer-sealer (which I already purchased). What type of oil-based primer would people recommend? Thanks!
I can't really tell what kind of paint the current surface (ceiling) has...
Old 09-26-2012, 03:52 PM   #12
Zinsser makes an oil base I think its in a gold labeled can. I have always had good luck with their primers. I always try to use oil in wet areas like kitchens and baths. Don't forget to clean up your tools after oil base you must use mineral spirits.
Old 09-26-2012, 04:42 PM   #13
chrisn's Avatar
Rewards Points: 310
Cover Stain
Old 09-26-2012, 05:46 PM   #14
Rewards Points: 200
Cover Stain
Oh No... I can't buy that oil-based primer in California, not even from online (see photo below):
Old 09-27-2012, 08:19 AM   #15
Then i don't think you have a choice but to go with a good quality latex primer and the zinsser you already have is one of the best imho
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
5000k Light Blulbs for Ceiling Fan Fixture (clean white light for living room) cmf0106 Electrical 10 01-12-2012 10:04 PM
Ceiling is very hot in the living room 3caddydaddy Insulation 4 06-22-2011 02:55 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Dining room renovation + Tray ceiling hyunelan2 Project Showcase 24 08-17-2010 09:43 AM
