Old 07-03-2008, 01:54 PM   #1
Need help with tape/Spackle repair....
In my newer (2004) master bedroom, we have cathedral ceilings. There are two joint's at the top, I believe each is a 22 degree angle?
Anyway, when the guy did all of the taping, he warned me that the tape on those angles my not "hold" but that was normal as you could not put compound on the tape like you normally would on other joint's, just on the edges.
Well, almost all of the edges are now coming up. I am assuming I need to rip it down and re-tape it, but do I tape it like any other joint or not?
I think I get the run around (all his other work was great) but this seems odd.
dcd22 is offline   Reply With Quote
Old 07-03-2008, 04:44 PM   #2
Is that the Apex or ridge? If not, then I would just cut out the old and in with the new.
mark942 is offline   Reply With Quote
Old 07-03-2008, 10:08 PM   #3
Remodeler
MinConst's Avatar
Maybe I'm missing something but I see no reason why mud couldn't be put under and on the tape. What difference does the angle make?
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 07-03-2008, 10:39 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
....uh....yeah...regardless of any angle or height, the proper way is the proper way
He must not have had a taping knife that would fit or something
Tape it like any other joint
slickshift is offline   Reply With Quote
Old 07-04-2008, 11:21 AM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
I would use the powder mix joint compound, it is much stronger than the all purpose premixed joint compound.IMO
Checkout some of
Sir MixAlot is offline   Reply With Quote
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
LB Mower Repair Question kennykenny General Discussion 1 09-23-2007 01:12 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 02:02 AM
