Old 12-08-2012, 08:46 AM   #1
need help sprucing up dark green stucco
Hey yall, I'm new here and I'd really appreciate any ideas on how I could go about sprucing up my dark green stucco house. I can't paint the entire surface of the house, but there are trim feaures around the edges and corners of the house/windows. So, I was thinking about painting those in a lighter color. Any ideas on what I should paint it?
Thanks!
Here's a pic
wisehunter1 is offline   Reply With Quote
Old 12-08-2012, 12:08 PM   #2
May want to consider adding some details around those windows.
http://www.fypon.com/literature/pdfs...owDoorTrim.pdf
Old 12-08-2012, 03:35 PM   #3
Gymschu's Avatar
A couple things you could think about.......maybe a cream colored trim color around the windows and/or adding some shutters. The very dark green makes your home look "boxy" and somewhat uninviting. Some lighter accent color(s) would tone down that stark green color & give the home some character.
Old 12-08-2012, 08:50 PM   #4
yea our garage door and front door have that cream colored paint... its hard to tell from the pics. I have a mock up of what might happen if I painted the features on teh stucco... its a very rough photoshop job Also, if I put shutters onthe windows, there's only 36 inches between each window. The windows are 24 inches wide... so I could have 12 inch shutters on each window leaving me a 12 inch gap between shutters... Will that seem too cluttered?
and if I do get shutters, should they also be in a cream white? Also, how would a lighter green (sage) look instead of the cream?
Old 12-09-2012, 11:22 AM   #5
Gymschu's Avatar
I actually like what you've done with the photoshopping, wisehunter. You might not need the shutters as it could get cluttered/crowded on the front of your house, although you can order shutters in just about any width you need. Maybe all that's needed after lightening up the trim is to paint the front door a bold, bright color to really make it pop, and even that is not necessary. I would continue to play around with the photoshopping to see what works for your tastes/preferences.
Old 12-11-2012, 02:29 AM   #6
ok thanks for the advice... I think I will go with the cream color since it's already on my garage and front door... However, I do have one more question. It's hard to tell from the pictures, but the stucco trim also goes horizontally along the top edge of the house right under the gutters/roof. It is continuous with the vertical features and also where it meets the top window trim. If I painted all of the trim, then it would form a box around the second story windows. Do yall get what I'm describing? Would it look weird? So instead of white collumns like in my photoshop,, it would also have the white trim going across the entire top of the house veertically right below the gutters.
Old 12-11-2012, 05:17 AM   #7
Personally, I think you have enough lines now. I would skip that detail. I wasn't sure how what you were describing would look, but I think I like it. You might think of a pop color for the front door, just the door itself. I have a question about the garage windows, are they boarded up or am I seeing into the unpainted garage?
Old 12-11-2012, 09:48 AM   #8
I would rule out the shutters I don't think they would look right with the narrow space between the windows, just my opinion. I must say I like the photoshop pic but be careful you can go too far. I would keep playing with the photoshop till you find something that really suits your taste.
Old 12-11-2012, 02:51 PM   #9
Yea I think I'll skip the shutters. I'm still hesitant as to if I should paint the accents or not. In another forum, someonwe suggested that I paint the accents a slighter darker green tone. With the contrast, it will make the whole house seem a bit lighter.
Old 12-11-2012, 05:37 PM   #10
Mr. Paint's Avatar
Amen to all! I have seen alot of homes with a dark green and ivory-colored trim and they go together very well, Stick to the scheme you have photoshopped and you won't go over the top.
Mr. Paint is offline   Reply With Quote
Old 12-11-2012, 05:38 PM   #11
Again just me but with the color you now have whice in the photo looks dark, you might consider the trim lighter for contrast, like a mint green, or along those lines. To go darker I don't feel would show up very well. Again just my opinion.
Waterproofing Stucco Paint AZSun Painting 2 07-27-2011 08:43 PM
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 07:23 AM
New stucco over old painted stucco exterior Sandstone Remodeling 1 03-31-2011 05:26 PM
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
