Old 10-28-2008, 02:07 PM   #1
Question
Need help:I painted cement floor & now need to seal it
Hello - I just faux painted my cement floor and it looks beautiful. I need to know what to do next. I put Behr concrete floor sealer on a small section and it dried with a hazy white film. What is the best sealer out there? I painted with latex after I primed the floor and I do not have any moisture problems.
Thank you for any and all advice,
Becky
ggsmom is offline   Reply With Quote
Old 10-29-2008, 08:55 AM   #2
Moderator
Termite's Avatar
I'm moving this to the painting section so you'll get better help...
Did you use paint intended for foot traffic and application to a concrete slab? Hope so....
Old 10-29-2008, 02:57 PM   #3
Firstly, why do you need to "seal" the floor? Paint itself is a sealer. If the coating isn't durable enough, the solution is usually more paint (of a high quality), not the application of a clear coating. I guess if you used wall paint on the floor, you would need to do something, but a quality floor paint should not need additional product.
However, if you must do something to the floor, get yourself to an actual paint store (NOT BigBox) and ask the folks there, who usually know waaaayyy more about paint than the guy behind the counter at BigBox.
SirWired
sirwired is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
