Need Help To Fix The Ceiling - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2009, 12:50 PM   #16
ccarlisle's Avatar
Despite our not knowing how large these chunks are, I think you're on the right track; most often I see these as 4-6 square inch sized imperfections in a ceiling, typically where moisture has gotten behind the last coat of plaster and caused these chunks to fall off. And joint compound is the way we fix them - if they're not too big or too many. But if a smooth overall finish is what you're looking for, a new ceiling made of 4'x8' sheets of half-inch drywall sheets is what is called for.
You have approx a 120 sqft ceiling so that's about four or five sheets at $10 each... You'll need some help screwing those sheets into the ceiling joists with drywall screws. Then tape the joints, sand, prime and paint.
OK sounds easier said than done, but it's not a hard job to do. May take several days while the joint compound dries, but do-able. Finicky work with the flaring of the seams and all, the pros make it look easy - but a good DIY project. You can always get a handyman to help hang the sheets as they weigh about 50lbs each I think...you can rent tools to help too.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 07-26-2009, 02:10 PM   #17
Drywall contractor
Rewards Points: 1,070
If at all possible, I recommend using the 12' sheets to eliminate the "butt" joints you will have using 8' goods. Those joints are the hardest to finish properly, especially for a DIY'er......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-26-2009, 06:44 PM   #18
Registered User
Rewards Points: 5,256
Break all joints, edge and end, differently than existing plywood. This may help: http://www.gypsum.org/pdf/GA-216-07.pdf
Be safe, G
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
