Need Exterior Paint In 'pints' - Painting - DIY Chatroom Home Improvement Forum
Old 10-09-2014, 09:14 AM   #1
Rewards Points: 2,038
Need exterior paint in 'pints'
Just got a heavy duty wooden bench, raw wood, that will be outside.
I want to paint it blue with yellow fish. Tried looking for exterior paint in pints and nothing. I'll prime then buy a qt of blue exterior. I guess I'll have to use what ever is available in yellow in pints. I'll probably use another color in a pint.
Then A final coat in a sealer to protect since the pints probably won't be exterior paint.
See how much I've learned on here!
Startingover is offline   Reply With Quote
Old 10-09-2014, 09:23 AM   #2
(the original)
Rewards Points: 756
Rustoleum has it in half pints.
ratherbefishin' is offline   Reply With Quote
The Following User Says Thank You to ratherbefishin' For This Useful Post:
Startingover (10-09-2014)
Old 10-09-2014, 09:55 AM   #3
Rewards Points: 12,846
Did you pick the color and asks the person in the paint dept. to mix a pint?
Often times it's in the pint cans marked light, med, or dark base and just needs to be mixed to your color.
Main reason is they sell far less pints so why have them all premixed and never sell them because there the wrong color
Old 10-09-2014, 10:10 AM   #4
Rewards Points: 5,974
I haven't seen them just in samples and they aren't meant as finish paint and I have never seen them for ext. If that is all you need make a stencil and use rattle cans.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 10-09-2014, 11:48 AM   #5
Should I still seal it with a clear poly?
Old 10-09-2014, 12:05 PM   #6
A Little Of Everything
Rewards Points: 1,362
At the SherwinWilliams store I frequent, I've gotten "sample mix" paint in quarts, for $7.00. Granted, that was interior paint, but I suspect they'd mix exterior as well.
DrHicks is online now   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
Old 10-09-2014, 05:52 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
no
The Following User Says Thank You to chrisn For This Useful Post:
Startingover (10-10-2014)
